Question about Bosch 11247 Factory Reconditioned 1 - 9/16" Spline Drive Rotary Hammer
Bosch rotary hammer (model # 11230EVS) drill will not rotate
The drill portion of the rotary hammer does not rotate when selected.
Examined the inner parts of the tool and cannot find any broken parts including the plastic selector. It does appear the selector does mate with the engagement ring (fig 149) and move the gearing (fig 51). However no rotation.
Question Are there any shear pins involved for safety reasons. If so where are they located.
Thanking you in advance.
Kevin
  • 154 Answers
There is a clutch in the main spur wheel of the unit. These sometime begin to slip, on rare occasions they will slip to the point where the drill will not rotate. If you are interested the part number for this clutch is 1617000817.
Posted on Aug 06, 2009
The selector knob broken,how to remove it
There are different knobs the old models have a knob they must jumped out but there are rotary hammers and drill hammers they have a red button in the knob that must push in and rotate clockwise setting to the end of it rotate hammer or 1 further only hammering and then push the red button more then normal with something and turn a little more further until its end and pull on the knob and feel it comes free.
Dec 27, 2015 | Bosch Drills
How do I replace brushes on this drill?
[PDF]Hammers and Hammer Drills - eBuild
www.ebuild.com/ImgRepos%5C2010%20Hammers.pdf_06072010_110..See pages 46-49,. 184-214 for hammer drill accessories. BOSCH. H a m m e rs a n d.... 11250VSRD - 3/4" SDS-plus® Rotary Hammer .... technician can quickly replacethe brushes and cord .... 11264EVS - 1-5/8" SDS-max® Rotary Hammer.
Oct 20, 2015 | Bosch 11264EVS 1-5/8 SDS-Max Rotary Hammer
Bosch 11230evs rotates even when set on hammer only
Could be the pin on the selector lever has bent or fallen out.
Oct 19, 2013 | Drills
Hammer function does not work on Bosch 11224vsr
Its usually a problem with the selector knob... depress the button fully and turn it passed the selection markings and pull it out to remove it
Aug 29, 2012 | Bosch Factory - Reconditioned 7/8" SDS -...
How to take apart Bosch 11230EVS to replace hammer piston
How do I replace the brushes in a boschhammer 11230evs?
Mar 02, 2012 | Bosch Drills
What's your problem? rotary hammer will not hammer
Look for a lever that has signs hammer/drill or just drill Place the lever in the hammer position.
Feb 19, 2012 | Bosch Drills
Runs but doesnt engage rotary or hamer. the machine itself looks in great condition its called bosch buldog extreme.
there is a selector knob on the side that controls the tool functions for drill only/hammer with drill/ and hammer only. make sure it is in the proper setting. If it still doesn't rotate then you have a gear or a broken selector. If no hammer then you have worn o rings or a stuck ram. try the selector first and if still no change please be more specific if no hammer at all, or no rotation even when selector moved.
Mar 03, 2011 | Bosch SDS-plus BULLDOG Xtreme Rotary...
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Connnect drill to keyless chuck bosch 36vfl1
Push or pull the business end toward the body while gently pressing and rotating the bit into it. The chuck will snap back up to retain the bit when you have it lined up right.
Sep 19, 2009 | Bosch 36V 1" Sds - Plus Rotary Hammer
Bosch 11222EVSG hammer drill not turning
Couple things to look at, First is the selector in the hammer/rotation mode? Without a bit in it does the collar turn when in the rotation mode. Are you using the right bits for this tool. If yes to all of these I would look down the spindle and make sure that the pawl are in place (they lock to the bit for rotation) Let me know and we will dig deeper.
Mar 06, 2009 | Bosch 11222EVSG 1 1/8 Inch Grounded Sds...
Bosch 11247 Factory Reconditioned 1 - 9/16" Spline Drive Rotary Hammer Logo
854 people viewed this question
Top Bosch Drills Experts
John Trevino
Paul Carew
Are you a Bosch Drill Expert? Answer questions, earn points and help others
