Question about Microsoft Office Outlook 2003 for PC
Can't back up data
<> C:Program FilesWinFaxDataStatus.WFD
The process cannot access the file because it is being used by another process.
<> ** Did not commit changes to the above store **
I've tried everthing.
Re: Can't back up data
That is correct, you need to exit the WinFax Controller before you can back up any of the WinFax specific files, such as your phonebooks and send/receive logs. If you use the WinFax backup, it will shut down the Controller first before attempting to back up the files. If this is not happening, then you have a problem somewhere else.
I suggest you disable the WinFax Service in Control Panel, Admin,Services. Stop the Service and set it to DISABLED for startup mode
more info at support forums
Posted on Apr 24, 2008
  • 1,006 Answers
Posted on Nov 01, 2007
0 characters
3 Points
How do I Repair of priv1.edb Exchange 2003 eseutil?
Are you using backup exec 9.1 by any chance?
There seems to be a problem (incompatibility) with win2k3 sp1 and BE9.1 - even the microsoft emphatically deny it.
I got around my errors in BE9.1 by not using the Volume Shadow Copy service
Just a thought. Or there is also the possibility to use third-party tools such as edb repair EDB Repair Kit. It can also help in your problem. Try to Use all the tools and some of them should help.
Look also this authoritative source.
Sep 29, 2015 | Microsoft Exchange Server for PC
How to repair Outlook folders using the Inbox Repair Tool
Inbox repair tool(scanpst) is the best tool that can be used when you are finding any difficulties to connect your inbox folders or pst files or it is reporting that your Inbox folders or Outlook PST file may be damaged in Microsoft Office Outlook 2000 (or higher).Scanpst is a tiny tool installed by default when installing Microsoft Office 2000 or higher.
PST files or Personal Folder Files are used by Microsoft Outlook for storing Outlook data, including mailbox files, email folders, contacts or any other personal data related to Microsoft Outlook.
By default, Microsoft Outlook stored these PST files at the following location:
"C:Documents and Settings\USER_NAME\Local Settings\Application Data\Microsoft\Outlook",
where USER_NAME is your Windows logon name.
The default PST filename for your active mailbox is Outlook.pst, while the archive file is stored as archive.pst.
"Before doing any types of repairing pls keep a back up of the pst files"
Using Inbox repairing tool
By default, Microsoft Outlook will install the Scanpst.exe file within your Program Files folder, in 'C:\Program Files\Common Files\System\MSMAPI1033'.
If you can't find the Inbox Repair Tool, you can download it from here then copy it to the above folder.
Make sure Microsoft Outlook is not running when you try to run the Inbox Repair Tool. When starting it, you should see the following screen:
If you get an error message like the following one:
then make sure you copied the Scanpst.exe file to the right location. If you still have problems running it, then search your hard disk for a file named "CNFNOT32.EXE" then run it: it should unpack and copy the Scanpst.exe file to its default path ('C:\Program Files\Common Files\System\MSMAPI1033').
Once you started the Inbox Repair Tool, use the Browse button to select your personal PST file. Remember, its default location is "C:Documents and SettingsUSER_NAMELocal SettingsApplication
DataMicrosoftOutlook",(It can be vary depending on how where you configured the pst files). where USER_NAME is your Windows logon name. Then click on the Start button. When the scanning process is done, you should see a notification screen like the following one:
Make sure you mark the checkbox for making a backup of the scanned file, then click on the "Repair" button. When this process is done, you should be able to properly start Outlook and use your recovered personal Outlook folders
on Mar 17, 2010 | Microsoft Outlook 2003 for PC
How do an user of Apple Mail transfer all data into Windows outlook?
Use a widows based Apple Mail to Outlook converter to migrate emails from MAC mail to Windows Outlook 2013, 2010 and 2007 etc. To perform the conversion process, you need first to export needed mailboxes from Apple Mail to MBOX files then convert them to PST format by using the tool. Read more details :-
Stellar Phoenix MBOX to PST Converter
Apr 20, 2015 | Microsoft Outlook 2010
Why can't I upload a file from my computer hard drive to google drive?
An example on how to download and save to an External Hard Drive and copy and paste to an External Hard Drive
Click start all programs accessories open windows explorer navigate to your data / files
Right click on the data select copy navigate back to the External Drive.
or right click on the data select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet.
Once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into your External Drive or a folder in my documents or another device or a usb device.
You might have to many programs trying to or accessing your computer or the internet at the same time or a virus
Scroll to bottom toolbar (bottom of screen) right click select task manager applications and processes to see you whats running and ticking over
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
You might have a virus or Malware.
Nov 14, 2013 | Internet & Communication Software
I have just deleted an album of photos from my sony cyber shot digital camera ny accident. Is there any way I can retrieve them ??
Hi, you can retrieve your deleted photos from your sony cyber shot digital camera . know that when you delete a file from your SD card or hard disk, the place is only for reuse but you don't actually delete your files forever. you will delete this files until you overwrite the place with you new files. So, stop using your camera card an retrieve your photos is possible. step by step guide to retrieve your photos from digital camera.
Oct 31, 2010 | Deleted Files Recovery Flash Drive...
I deleted video from my sony sr47 handycam, it now shows a broken icon where the video was, can I recover these?
I have had success with this file recovery program called asoftech data recovery... Download the data recovery program
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the file recovery program, then select the drive where files are deleted, then press "Next" and wait for it to do it's magic.
Oct 08, 2010 | Deleted Files Recovery Flash Drive...
Restoring outlook data files
Try File --> Import and Export --> importing from anothe file or program --> Personal Folder File (.PST)
Sep 28, 2008 | Microsoft Outlook 2003 for PC
Microsoft Office Outlook 2003 for PC Logo
222 people viewed this question
Top Microsoft Internet & Communication Software Experts
Alex Krenvalk
Brian Sullivan
Brian Sullivan
Are you a Microsoft Internet and Communication Software Expert? Answer questions, earn points and help others
