Question about KLH Televison & Video
Need to set channels no remote - KLH Televison & Video
  • 92 Answers
Can you get in the menu screen with the built in buttons on the TV? if yes then go to menu, go to tuner, select antena or cable, and scan.
Posted on Jun 16, 2009
Without remote how do I set in on channel 3, the channel button of front of TV only goes from 95 to 99 and back again.
you will need the remote to do a channel search or manually reprogram the tuner to tune in ch3
A good place to fine cheep factory remotes is on e bay. enter your model and make, only buy factory remotes not universal .
Factory remotes can do things a universal one cannot.
Jan 23, 2016 | Televison & Video
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Television model tp2784c101 what is the remote control menu/set up to keep channel so it doesn't automatically switch to different channel after 30 seconds; or how can I set it up to turn onto AV1 an
If the TV do not respond to remote control; to change channels, there are many possibilities. Check the infrared emission of the remote control first. Check it with fresh batteries. If the infrared sensor inside the TV is faulty, this kind of fault can happen. In other words, your TV need a through check up, which a normal user can't do with ease. Contact any service technician; or the authorized service centre. Electro help
Nov 18, 2014 | Philips Magnavox 27MS343S 27" TV
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
My DMR-EH50 is stuck in SP mode and when I hit the button on the remote it keeps displaying CHK REMOTE 3. Would you know what is causing this. I cannot get the unit to do anything at all.
Very easy fix.
Your DVD recorder can be set up to accept remote contol signals on any one of three channels. Remote 1, Remote 2 or Remote 3.
Your remote can be set up to send signals on any of these channels. You need to make sure your recorder and remote are set to the same channel.
Your recorder is telling you that it is set to receive remote control signals on channel 3. This means your remote control is currently set for a different channel.
Assuming that you have a genuine Panasonic remote, do the following,
On your remote press the "Enter" button and hold it down. Then press the "3" button at the same time for two seconds, then release both. This will change your remote so it sends signals on Channel 3 which will match your recorder.
Those clever people at Panasonic realise that you will be delighted with their products and will probably have several of their appliances in use. The different channels avoids switching all your Panasonic gadgets at the same time. Clever huh?
Best wishes
Aug 24, 2010 | Panasonic DMR-E50 DVD Recorder
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Using my universal remote contol,lost sound on 2 TV channels
The solution is to change the audio input from SAP (secondary audio programming - default on TV sets sold in Canada) to Stereo or Mono. Your remote will need to be able to access the "Menu" settings screen for your television set.
May 07, 2009 | Samsung TV Remote Control
Hi, when i press any key on the dvd recorder remote (panasonic dmr-e55) i comes up with remote dvd 1 everytime and wont do anything else, weve tried umplugging it 2 but that doesnt help, do u have any...
Very easy fix.
Your DVD recorder can be set up to accept remote contol signals on any one of three channels. DVD 1, DVD 2 or DVD 3. Your remote can be set up to send signals on any of these channels. You need to make sure your recorder and remote are set to the same channel.
Your recorder is telling you that it is set to receive remote control signals on channel DVD 1. This means your remote control is currently set for a different channel.
Assuming that you have a genuine Panasonic remote, do the following, On your remote press the "Enter" button and hold it down. Then press the "1" button at the same time for two seconds, then release both. This will change your remote so it sends signals on DVD 1 which will match your recorder.
Best wishes
Dec 29, 2008 | Panasonic DMR-E55 DVD Recorder
Channel keeps skipping on rca t.v
Problem with channel skipping has rectified itself. I simply unplugged the set and and started over with remote intructions on signal and channel setting. The tv was also turning itself off and on, this also has ceased. Thanks, hope I don't need you later.
Nov 24, 2008 | RCA Universal Remote Control
Televison & Video Logo
96 people viewed this question
Top KLH Televison & Video Experts
Steven Wander
Steven Wander
josepovedaca
Level 1 Expert
ray gallant
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
