Question about Hitachi VTFX631A VCR
Hitachi F361 VCR Digital Auto Tracking (not 631!)
While watching Comcast Cable -- routed through the F361 VCR into a Samsung TV (Model # TT20A54) via standard "coaxial cable" -- I accidentally hit a button (don't know which) on a (universal? Zenith) remote control -- that "triggered" the TV into "Line In" ("mode"); and I cannot "trigger it back out"...
What I've tried:
1.  TV has no "TV-Video" toggle switch (it's a combo TV/VCR)
2.  When I bring up the "menu screen" for the TV "Settings" -- I cannot select the various options of:  "antenna", or "cable AFN", or "cable H--?"; -- but it stays "stuck" on the "standard cable" option Only!
3.  I cannot view the Hitachi VCR "menu screen" -- to determine whether it is set on "Line In" mode -- but I suspect that it is; because an "L" shows on the front panel display when I depress the "channel down" remote button; whereas, (beforehand) while watching "cable (Comcast)" -- I believe that it went to "Channel 1" (or "Aux" (Auxiliary)) mode on the TV screen.
4.  I've turned off both the TV & VCR (disconnected power) -- but both seem to still "come up" in the same "line in" mode.
5.  Hitachi does not have a user's manual (so I could determine how to "reset" the VCR) -- since it's an older model; and Samsung has no user's manual -- since it is a "non-USA" (or European type-style) power cord!
(Note:  6.  I can still watch videos just fine on the Samsung (TV/VCR combo)).
My Ideas at present are:
1.  Find a (different) more versatile? Universal Remote -- to see if it might have a "toggle switch" to "trigger" the VCR, and/or the TV into "normal" (rather than "Line In") mode; or
2.  Use a (different) TV -- hook it into the Hitachi F361 VCR (hoping that it also will not be triggered into "Line In" mode) -- and attempt to bring up the VCR menu screen -- which would allow me to reset the VCR into "normal" mode; -- but, would that also (subsequently) trigger the Samsung TV back into "Normal" mode?
Thanks for your wonderful help!!
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Posted on Jan 13, 2008
Cannot get video on my Orion model VRO 211B
Could be a connection problem. Pins on plugs can become bent or damaged, sometimes it is the socket that the plug fits into that becomes damaged. Try a different connection lead.
Dec 26, 2015 | Orion VR0211B Video Cassette Recorder...
Apex Digital LD4088 LCD TV has horrible quality on cable but fine quality with dvd or ps3
try if you are not, routing signal for comcast via the rear AV jacks--if poor reception that way not the set but the incoming signal.
Most people who are paying for cable or whatever do not complain hard enough--just accept lousy signal and pay for it.
If its poor complain and keep complaining----in most cases there are alternate signal providers eager to jump in.
May 28, 2012 | Apex Digital LD4088 LCD TV
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Comcast Digital Conversion box (cable TV)
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Jun 29, 2009 | Allegro DVD/VCR ABV511
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
Can't tape tv program on VCR while watching another show on digital cable.
If you set it up right per Comcast instructions:
Your VCR will record a show off of its built in tuner while you are watching another show from the cable box.
Make sure that the AB switch is set into the correct position and that you are only recording a show that that isn't digital. I believe you can only record shows up to channel 150 off the VCR tuner. Anything higher than that won't work.
If your Comcast Cable Tuner has two AV outputs in the back of it, you can skip the AB switch altogether and plug the one of the cable tuner output lines into the back of the VCR input lines. That way it can record that show you are watching on the cable tuner at that same time.
Jul 19, 2008 | Televison & Video
Not able to connect Sharp Model 25h-M60 to Laptop or DVD player
Use a VCR as a A/B switch. Run Cable signal into VCR. Run coax cable out of VCR into television. Connect DVD to VCR (line in) using RCA cables. To use DVD, set VCR channel to L1 or L2 or AUX, depending on VCR type. Set VCR to channel 3 or 4 to watch television. VCR must be powered up to watch DVD.
Apr 10, 2008 | Sharp 25H-M60 TV
"Line In" mode (on both TV & VCR) -- (Please help) "Get (them) Back to "Normal"!"
it sounds like you need to get a universal remote that has an av setting on it usuall this is 0 or an av button this shoud toggle between these modes sorry couldnt be any more help
Oct 31, 2007 | Televison & Video
VCR Hitachi F361
The noise from the TV is called 60 cycle hum and it is caused by a capacitor that is open, a test for ripple voltage will confirm this The noise from the VCR is more then likely common mode noise which would not be heard but for the bad capacitors in the TV. Simply put the common mode noise is being added to the 60 cycle hum. Now for how to fix this, if you have a background in electronics you can use a schematic, multimeter and an oscilloscope and Multimeter to find the bad capacitors, and the schematic to tell you what the voltages and %ripple should be. If you do not have a background in electronics, take the set to be repaired
Sep 29, 2007 | Hitachi VTFX631A VCR
Hitachi VCR F361
You need to change the Audio / Control Head, as well as the Pinch Roller of the machine. A worn out Audio cum Control Head will reflect in poor tracking and so will cause the above problems.
Televison & Video Logo
454 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
