Question about Bamix De Luxe Hand Mixer
Bamix hand mixer seems to be stuck
Motor turns on but blade doesn't turn-feels stiff.
  • 1 more comment
  • Anonymous Feb 22, 2008
    The motor doesn't seem to have full power and the blade rod doesn't turn.
    I've tried lubricating the rod after removing the attachment guard, but it still doesn't work. It is just very difficult to turn the rod.
    Exactly as described by Ellisonb
  • Anonymous Sep 12, 2008
    Actually, I HAD the same problem. I just applied both solution, very hot water mixed with vinegar, and after 15 minutes my Bamix was functionnaing again. Marvelous! HD
We use the Bamix daily to froth milk for coffee but find that over time, milk accumulates inside the shaft and forms a glue. Soaking the shaft in white vinegar seems to do a great job of dissolving the milk glue and freeing the shaft again. We typically soak it overnight and have never had it fail.
Posted on Feb 06, 2008
It says in the manual to soak it in very hot water for 10-20 minutes, then try again. This should free trapped food from the shaft
Posted on Nov 09, 2007
Shaft does not rotate motor workink
My Bamix stopped working--no shaft movement and loud motor noise (think disuse caused motor lubricant to thicken). Propped it upside down and put drops of quality machine oil at seam where narrow blade shaft enters larger shaft (in center of curved guard). Probably not necessary, but added a few drops where large shaft enters handle. Oil slowly seeps in. Attached a blade to manually turn for oil distribution. Did this periodically over several hrs. Turned on low speed and it gradually returned to full speed capacity.
Oct 25, 2013 | Bamix De Luxe Hand Mixer
Attachments falling off Bamix hand mixer. How can I fix this
Tighten the base, carefully with needle nose pliers. I mean the base of the attachments!
Jun 20, 2011 | Bamix De Luxe Hand Mixer
One of the blades seems to be firmly stuck in the blender which mean that I cannot use any of the other components
give us a try at www.ctscanfixit.com we can repair all your restaurant equipment and answer any questions you might have
Mar 10, 2011 | Bamix 391100 Mixer
Where do I get new blades for my Household Blending Mixer HA-3058
It seems you can no longer buy the MegaMixa HA-3058 however Bamix sell a similar product - in fact apart from a couple of aesthetic modifications it seems to be the same machine....
They sell many accessories and you can get blades. Check:
www.bamix.com
www.bamix-blender.co.uk
I have both machines and the blades are identical and inter-changeable between models.
Feb 23, 2009 | Food Mixers
I can't remove the blade from my Bamix hand blender
Shaft should be free for rotation that is ok.
Blade will come off with determined force of pull make sure grasp blade with towel to prevent injury to the fingers.
Dec 13, 2008 | Bamix De Luxe Hand Mixer
Bamix slowdown - repair service anywhere out there?
click on the "contact" link in this website http://www.bamix-usa.com/ there's places in Canada & the US to have them serviced. Through contacting them they'll give you the nearest service area.
Good luck, love my Bamix!
Aug 11, 2008 | Bamix De Luxe Hand Mixer
Attachments fall off
Excerpt from: http://www.bamix-usa.com/
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers
Feb 23, 2008 | Bamix De Luxe Hand Mixer
Blades
The blades pull straight off the shaft. If you look closely you will see a small notch on the blade that fits a tab on the shaft. This keeps the blade turning at the same speed as the shaft.
Anyway, pulling straight down on the blade should get it off. You might try boiling the tip in water to soften whatever gunk is holding it on. Be careful you don't burn your fingers when trying to pull off the blade after boiling it.
Sep 21, 2007 | Bamix Mono Mixer
Bamix De Luxe Hand Mixer Logo
1,162 people viewed this question
Top Bamix Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Bamix Food Mixer Expert? Answer questions, earn points and help others
