Question about Timex 27191 Wristwatch
I replaced the battery and it still does not run
I replaced the battery and and cover and it still does not run
  • 58 Answers
The watch may have been wet or damp, or it may need servicing, due to dust etc getting in
Posted on Jun 22, 2009
Back has NO screws. How do I easily remove it to replace the two batteries?
Hi, You may know that this watch runs on two batteries, one for digital display and another for analog hands.
If the analog hands stop working all you need to do is to replace the battery and please replace both at the same time since the band and cover take some effort to remove.
You need to take off the both bands first to access the back side than the back cover with a small knife..
Just in case,if you need the user manual here is the link.
Timex watch: http://www.timex.com/info/Product_Instruction_Guides_Downloads .
Take care..
Regards
Jun 14, 2011 | Timex T56381 42 Lap Ironman Triathlon...
How do you remove back cover to replace 296 wrist watch battery
Thank you for contacting FixYa.
  • Place the watch face-down on a clean towel to protect the crystal.
  • 2
    Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
  • 3
    Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
  • 4
    Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
  • 5
    Take the battery with you to a watch shop or electronics store to buy a replacement.
  • 6
    Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
  • Sep 14, 2010 | Peugeot Watches
    How do I get the back of my watch off so that I can change the battery? Womens watch model NY-3196
    If you have a watch with a dead battery, you can replace the battery yourself. However, it is often difficult to remove the back cover of the watch case. Every watch is different, some may unscrew, while others will pry off, particularly common in less expensive watches.
    Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
    Pull out the stem, which releases the back on some watches.Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
    Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
    Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
    When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
    Or you can take to local jeweler to have them professionally do it with professional tools for between $8-15. My best advice there.
    Jul 26, 2010 | Watches
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    How do I reset my Casio PRG-40 following battery replacement?
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
    Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
    I am writing to file a complaint regarding my wife's watch. The watch was purchased Dec. 2008. It stopped working twelve months later. The limited warranty stated that the watch would be repaired for...
    Warranties only cover a failure due to manufacture. Unfortunately dead batteries are not covered by any maker as there is nothing wrong with a watch if the battery fails.
    I year does seem a little short. Perhaps it was running for a time before you bought it? Who knows!
    Feb 16, 2010 | Watches
    Need help replacing battery in my nike Imara Womens watch? Which way does battery go in with plastic cradle?
    1. Use a coin turn the battery hatch one-quarter turn counter-clockwise
    2. Remove old battery from compartment. Keep plastic cradle and replate with 395/SW927R battery. Replace the new battery positive side facing up in the plastic cradle into the metal compartment in the watch. Ensure all three little tabs line up and twist cradle to lock into place. Make sure the O-ring is in proper placement on the cover and replace the battery hatch ensuring it is sealed completely!
    Jan 28, 2010 | Nike Imara Run WR0075-014 Wrist Watch
    NEW BATTERY. NO CHIME OR BEEPS ON THE HOUR,TIMMER, AND ALARM WHAT CAN I DO TO FIX THIS PROBLEM
    could be following reason
    1, you did not put case back correctly,
    2, small spring which connect watch movement from caseback for chime lost during battery change ,
    3, may be required reset of AC & Battery plus ,, by twizer
    hope this help
    AmFix Jewelry2.gif & Watch Repair
    203 N. LaSalle st
    Chicago, IL 60601
    Ph: 312 641 7000
    email: info@goamfix.com
    web: www.goamfix.com
    Sep 14, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
    Watch casement cover replacement
    looking for a battery cover to suit model D 377 tissot men's twotimer II vintage 1992.
    Jun 19, 2008 | Watches
    Timex 27191 Wristwatch Logo
    172 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    deton8 von Splosion
    Vladimir Frolov
    Are you a Timex Watch Expert? Answer questions, earn points and help others
