Question about Samsonite Tripod
My combination for samsonite suitcase no longer works what to do?
I've had my samsonite suitcase for several years now and the combination no longer works. what can I do apart from bust the lock?
thanks very much
and regards
marie
  • 3 Answers
Is it locked shut?
Posted on Jun 22, 2009
If it is locked shut then all u need to do is get a flashlight and shine it directley into the little crack on the right side of each wheel. Once u have done that on the first one u will see an indentation that looks like a square and it should be face up and dead center for each wheel. You will b able to tell when you have all 3 lined up and that should b your combination. Well if for some reason that does not want to work all you need to do is -5 from the first number of your comb. then go to the second one and +5 and do the same to the third one and this will bypass the faulty combo and will allow the springs underneath the wheels to align right so that you can open it right away. This is the factory default way to get around a combo that will no longer work.
Posted on Dec 01, 2011
How to reset a combination lock for samsonite luggage?
if the suitcase is open, look for a little red tab on the inside. Move it to the other side of the little window, then change the combination. If the suitcase is locked, you will have to try from the outside to find the correct combination
Mar 11, 2015 | Samsonite Photography
I have forgotten combination tomy suitcase and it is locked how can i get it unlocked
Start at 000 and go up one number at a time until it opens or reachest 999.. it will take some time. .. good luck.
Dec 01, 2014 | Samsonite Silhouette 11 Hardside Spinner
Samsonite oyster 1992 lock reset
This should help whether you know the old combination or not.
How to Open Combination Lock on Samsonite Suitcase
Jun 01, 2014 | Locks & Locksmithing
Roncato suitcase forgotten my combination and cant open the suitcase
I have a Roncato hard shell with a 3 digit combination lock under the handle. I set the combination YEARS ago, had a young child play "horsey" on it, and turned all the numbers! The suitcase was locked and I had forgotten the combination. I followed the instructions in answer 2 above and it worked! I didn't have to add or subtract 5. I used a small sewing needle and a strong flashlight - the indentations were easy to see.
Feb 11, 2013 | Samsonite Photography
I have a Samsonite suite case that has not been used for some time many a few years due to forgetting the combination code. Can you help as i am now in need of another suitcase and do not want to have to...
You can open combination locks by pulling on them and then rotating the rings until you feel the mechanism "give".
I'm not sure if this would be too successful with a suitcase but it is worth a try. Use a screwdriver to gently pull along the axis of the lock and rotate one furthest away from the catch.
Rotate it until it goes slack and then feel for the next one along and repeat.
Continue until all the tumblers have loosened, when the lock should open.
Some patience and practice needed.
Jan 06, 2011 | Samsonite Silhouette 11 HWatch
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
I have Samsonite suitcase with the lock type B. When I used it last time, it was working. Now the code system doesn't work at all. I carefully followed the instruction to lock it but the code doesn't work,...
did you do this...
STEP 1 Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2 Locate the reset button, usually placed to the side of the combination dials.
STEP 3 Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4 Release the reset button after you set the numbers to the new combination.
STEP 5 Test the combination by turning the dials to the new code to open the lock.
if you did this then I'd contact Samsonite Customer Service at 800-765-2247.
Happy New Year
Jan 01, 2018 | Health & Beauty
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Oct 16, 2009 | Samsonite Tripod
I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Apr 11, 2009 | Samsonite Tripod
Photography Logo
1,920 people viewed this question
Top Samsonite Photography Experts
timtak
Level 1 Expert
Marvin
Marvin
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
