Question about Leviton D4DMX Programmable Channel Dimmer Pack System
Leviton Repairs I use 4 Leviton dimmer pacs on my system. I used it 6 times in the last 3 years. One of my pacs does not respond. I checked the fuse and it was blown. I replaced it and plugged it in and seen some smoke come off the transformer. Can these be repaired? Thanks D Vandenberg
Re: Leviton Repairs
If you want to spend more than they are worth. For a real solution buy dimmers from a quality brand such as ETC Electrol or leprechaun
Posted on Jul 10, 2008
0 characters
3 Points
Red light is on in the back of my t300 tower speakers
That is the standby mode but if its not kicking out of standby mode it could be a fuse issue
The T300 uses a 2.5A fuse.
To replace the fuse:
1. Unplug the AC cord from the AC power source,
then remove the AC power cord from the speaker's
power connector.
2. Remove the fuse cap with a small, flat blade screwdriver
(see diagram 2).
3. Remove the fuse from the fuse cap
(see diagram 3).
4. Replace the fuse inside fuse cap with another metric
5X20mm size fuse
5. Replace the fuse inside the cap, replace the fuse
and cap in the power connector (see diagram 5).
6. Connect the AC power cord to the speaker and
raise it upright.
7. Connect the power cord to an AC power outlet
Jun 01, 2011 | Cambridge Soundworks ton Theater T300 Home...
I Have samsung HT-P10, Pl let me know the laser lens number is used for the same or let me know any satiable lens which can be used for HT-P10
Hi.. my home theater system HT-P10.... is not working.... Any of its function do not respond after it being kept on...! Any of its function are not working.... the dvd player doest open up.. nor sound comes out of auxiliary, radio or any other function... and the 5.1 display is never shown.. it shows 2 channels only..
and this had been the problem frm last 1year.. at the beginning of the year... it was working suddenly in between and at times it use to turn out inactive but from last 6-7 months it is totally inactive...!
I contacted and the guys came down to my house telling that we dont hold any spare parts of system we cannot do anythin...a do they say we do not repair...!
So what to do to repair it.. can it be..? nd can i ever use its sond sytem only.. in any form.?
Sep 14, 2010 | Samsung HT-P10 Theater System
Channels 3 & 4 go to full on only. They do not dim.
The electronic part (a triac) that does the actual dimming in the bad channels is shorted, so the lamp always comes on at full brightness. Unless it's a special part or the manufacturer has removed the device markings, it's possible to identify the bad parts and replace them. Electronic components are available from a number of online sources (MCM, Encompass and others), or maybe even locally. Most musician supply stores have service departments or can refer you to someone if you don't want to try repairing this yourself, or you can see what service options are listed in your manual or on the manufacturer's website.
Feb 19, 2010 | Leviton D4DMX Programmable Channel Dimmer...
No power to Insignia dvd player.
Pop the top of the DVD player and check the fuse. It's located right next to the AC power plug on the inside. If the fuse is OK, replace the DVD player. Repairs cost more than a new unit. Sony has DVD players from $ 40. Any repair on any device would cost more than that. If your lucky, the unit just took a surge and blew the fuse. Hope this helps
Oct 14, 2009 | Home Theater Systems
Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Sep 07, 2009 | Bose 3 2 1 GSX System
2005 350Z 6 disc changer / error message
Use a Laser Lens Cleaner. Run it thru the player a couple times. Use one that has fluid with it, you can find them at any electronics retailer for 15-20. If it still has the same problem, the only thing to do is send it for repair, they will replace the transport. Average cost of 125-175 on a changer. Hope this helps
Jul 01, 2009 | Bose 3·2·1 II System
Bose 3-2-1 remote control
But a new remote. Non repairable item. Just worn out.
Jun 07, 2009 | Bose 3 2 1 GSX System
Time Signature
What options do you actually have on the gadget? keep us posted...
Nov 29, 2008 | Alesis 16 Bit Stereo Drum Machine System
No power to player!?
the fuses are the first obvious suggestions.
in the main AC plug, and if theres any sign of fuses on the Circuit board itself.
If it,s over 2 years old, i,d think about getting a replacement.
as repairs nowadays cost an arm and a leg, and only usually warranted between 30-90 days.
If it,s done it,s job. then it,s time to think about a replacement.
Mike @ Compurepair.
Feb 22, 2008 | Sony DAV-DX150 System
Samsung HT-DS610 System Problem
I found this online. Don't know if it helps you guys or not?
Samsung HT-DS610
1. Remove any discs from the tray
2. Flash the RAM (disconnect from the mains for 30 seconds)
3. Plug it back in, switch on from the remote
4. Wait for "No disc" message
5. Press Enter.
6. Press 8,4,2,6,9 slowly.
7. Press Enter.
You may need to repeat steps 4 through 6 before the try is open.
Nov 25, 2007 | Samsung HT-DS610 System
Leviton D4DMX Programmable Channel Dimmer Pack System Logo
175 people viewed this question
Top Leviton Home Theater Systems Experts
Gyula Lacz
Are you a Leviton Home Theater System Expert? Answer questions, earn points and help others
