When multiple pages are printed it's like the temp drops and starts off setting. If you print singles it works fine. Customer using plain paper I've recomended color print paper but not sure how to change settings for paper type.
Need a fuser to resolve the issue.
Adjust ATS sensor (PL8.1, item 74) .
When the ATS calibration utility fails to run and stops on media feed, wait 10 seconds and press 'cancel' to return the ATS 4 sheet Calibration menu. Select 'Display Results' and scroll to the No Paper KHz sample page. '1=' will have a number displayed. Note the number.
Power off and open the top cover.
Locate the ATS sensor, there is a hole in the cover and in the hole, a white nylon slotted screw head (PL8.1, item 69 ).
Each click is about the 25 KHz. Clockwise will increase the setting, Counter Clockwise will decrease the setting.
Adjust the gear so the setting will be 290 plus/minus 25 KHz. For example, if the No Paper Sample 1=210, three clicks clockwise will bring the setting to 285 the next time you run the ATS calibration utility.
Close the top cover, power on and enter diagnostics. Re-run the ATS 4-Sheet Calibration utility. The ATS should now set up correctly. You must do a power cycle between failed ATS setup
Plain paper is not the problem.
But above is the setup/
