Question about Dryers
The dryer heats and shuts off in about 30 seconds repair guy has changed a thermo fuse? and i still have the problem i've checked my ducts no blockage it runs on air and delicate fine but on reg heat in less than a min when it gets too hot its cuts out
  • 89 Answers
Its your timer that needs replacment. not the thermal fuse.
if the thermal fuse was ever tripped, it would not start at all. you would only hear the ticking of the timer.
if other cycles work its the timer not any of the sensors or fuses.
dryers are very basic, and are completely controlled by the timer (or control board for digital models)
Posted on Jun 16, 2009
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
I have a 70 series kenmore dryer bought it from a used appliance guy cant find him now it worked find for a month now it doesnt heat up! been lookin online seems its most likely to be the thermo fuse or...
The thermo fuse will not cause your problem. If the fuse is bad it will cut the dryer off compleatly.
There are two limit switches on the heater can and the heating element. If you have an ohmmeter you can test for continuity across the element and the limit switches. If one of the limits is open replace both limit switches and if the element is oepn replace the element.
This page will help more http://www.appliance-repair-it.com/Whirlpool-dryer.html
If you don't know how to use an ohmmeter this page will help
http://www.appliance-repair-it.com/ohmmeter.html
Sep 24, 2010 | Kenmore 62602 Electric Dryer
Gas dryer heat not going on. Vent is now
In duct area there is a thermo switch. 1/4"x2" white in color. two wires are connected to it. This goes bad from overheating due to dirty duct work. This stops dryer from firing to ignite gas. Replace and you should be good. You can check all other thermo switches with a tester. Some are silver and round some are what I stated.
Jun 06, 2010 | GE DCVH515GF Gas Dryer
How do I find the thermal fuse to a Kenmore Dryer? It comes on and spins but no heat.
for kenmore dryer the thermo fuse, most often they are on the air duct. or located on the heating element can. The can is located on the bottom right in the dryer and holds the heating element..hope this helps pls do let me know
Jan 12, 2010 | Kenmore Dryers
My bottome dryer wont heat up but the top dryer heats
I have the same problem and called a repair center to fix. They came out last Thursday and and ordered the parts (thermite and thermo fuse). Waiting for a call that they received and ready to repair.
Aug 01, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Should I replace t-stats and/or hi-limits and thermal cutouts?
i have fixed thousands of dryers over the years and the element shorting to ground is a rare ocurance.if you are loosing elements this fast it is due too your ducting as i think you know.and your replacement of the flex with hard ducting will surly aid in that cause.too answer your question,sure the thermo's will have been weakened but i have seen the same thermo's on 15,20 year old dryers ,so they can take some punishment.i owned an appliance repair buissness for ten years and after market wholesale thermo's were about 3$ each so if could find at that kind of price ,ok.other wise may be looking at 30 to 40$ and i dont see it making your dryer much safer then is with out new. God bless,hope that helps,tom
Jan 22, 2009 | Kenmore 64942 Electric Dryer
DRYER NOT PUTTING OUT HEAT
If you can find the wiring diagram inside the rear service panel of the appliance, follow the circuit to identify the overload sensors. There are several internal temperature sensors in the heater circuit that could be open.
Also check that the vent duct, all the way out to the discharge grill outside of the house, is not partially restricting the airflow. Note the same for the lint filter on top as well. Any restriction to airflow will cause poor or no heating problems.
Check for a good discharge of air with everything hooked up, outside where the dryer vent discharges, while the dryer is operating.
Plase feel free to reply your findings, and if you have any additional questions.
Jan 19, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
T700 Dryer Won't heat
not turning off, is caused by a small stepper motor attached to the back of the timer, that actually moves the timer (if a mechanical knob, my memory for obscure (sorry) models isnt perfect) they fail and are replaceable, separately to the timer, or the timer can be replaced with a rebuilt one, at approx the same cost as buying a stepper motor,
No heat is caused by the failure of a thermal cutout(thermal fuse overtemp cutout or any of a dozen other names) a small device like this 5850e1d.jpg or this 4947033.jpg screwed on the ducting between the fan housing and the exhaust, with wires to the terminals.
when you stopped the unit while it was very hot, heat built up enough that the thermal cutout melted. test with ohmmeter or bulb and battery, no conduct -replace
Notes
There are only a few cutouts common to most dryer models the local parts guy will have one to fit, even if marked with a different brand name,
generic compatible timer available at local parts guy
saving a 100mile drive
Sep 09, 2008 | Asko T701 Electric Dryer
Cycles but no heat
The igniter needs to be near the burner jet in order to get a flame started when gas is provided,, the thermo fuse should be situated on the heat duct. I do not have access to Kenmore service manuals to provide any specific darwing details.. my comments are based on other brands.. I hope this helps..
Aug 30, 2008 | Kenmore Dryers
Dryers Logo
94 people viewed this question
Top Dryers Experts
Marvin
Marvin
