Question about Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit integrated dishwasher stopped working.
My Indesit D1620 built in dishwasher has stopped working. Green light no:2 flashes for about 15 seconds, then no:3 starts flashing, then the pump starts to drain and no: 1 light starts to flash. Can you please tell me what the problem might be. Thankyou
  • 27 Answers
SOURCE: Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Posted on Jun 26, 2007
SOURCE: Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Posted on Sep 23, 2007
yalmer
  • 552 Answers
SOURCE: Indesit DIF04 integrated dishwasher
Dishwashers normally are hot or cold feed.
My wife runs water at the sink to get it hot going in before turning on the dishwasher.
You can use either cold or hot water.
We have ours hooked up to the hot water side.
They work better hooked up to the hot water.
Posted on Mar 21, 2008
  • 14 Answers
SOURCE: Philips Whirlpool Integrated Dishwasher
Model numbers that are worn or missing are hard to find. When you go to whirlpool's website you might find your dishwasher there, other wise it might not have them listed because it is obsolete.
One place to look is on the panel below your dishwasher door. In some cases it is stuck there, or somewhere else under the dishwasher.
I have seen them inside of the dishwasher housing (under the cabinet between cabinet and dishwasher.
Very rarely will you find the model numbers inside of the dishwasher doors. However according to Whirlpool, if you open your door, you will find a sticker or a riveted plate on the right hand side of the dishwasher's frame, near the seals.
One thing I suggest however once you have discovered the model number, write it down and put it someplace safe.
Good luck
Posted on May 24, 2008
SOURCE: indesit idl530 2 flashing lights
no, turn the on / off button off, then turn off the power for about 5 minutes and then it should work again. and at some point do contact someone to look at it.
Posted on Jul 13, 2008
Need manual for indesit dishwasher d1620 please
Visit this link to download the Dishwashers DI620 User Guide (pdf format)
Hope this helps (remember to rate this answer).
Jul 07, 2011 | Indesit 24 in. DI67 Free-standing...
Indesit dishwasher IDL505 green light flashing water not entering the machine
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 27, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Dishwaher not working
switch on water appears to run in after a few minutes second and forth green lught comes on and machine stops it is a IDL500 indesit machine
Jan 09, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Green flashing lights , what does it mean ?
I have an Indesit IDL 500, the machine will start fine but after about 20 mins the Ist and 2nd button start flashing. Can you help?
Regards
Ingrid Houben
Jul 06, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
D1260 indesit dishwasher
The pump is situated underneath at the right hand back of the machine, you will need to remove the right hand panel to gain access. its not an easy job as it will probably need replacing. a local engineer should charge around 60-70 gbp
Dec 03, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
INDESIT IDL705
Sounds like an water inlet valve problem
Jun 28, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Aug 24, 2006 | Indesit 24 in. IDL700 Built-In Dishwasher
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
150 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Marvin
Marvin
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
