Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water is leaking from under the frig side and the evap pan is dry
Thereis ice buildup in the bottom and lower part of the freezer compt
  • GE Master
  • 4,655 Answers
Then your defrosts drain is blocked at its beginning, inside and at bottom of the evaporator tray. You will need to unplug, remove back panel inside freezer and lets have a look at the condensate drain entrance.If you want my assistance please let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Posted on Jun 16, 2009
My daewoo fridge freezer is leaking water from somewhere inside my fridga the model number is FR-4506S How can i fix this
Unless it has a water pipe plumbed into it then the water is melting ice or condensation, it's supposed to do this. You need to put a tray or some paper under it.
Jul 09, 2016 | Daewoo Refrigerators
Ice in bottom of freezer. What causes this?
Usually cause by a clogged drain in the back of the freezer. try to clean with hot water and make sure the water goes all the way downn to the drain pan. .
Note: all frost free refrigerator defrost a couple of time a-day; the water needs to drain into the drain-pan under the frig. check under the frig to see if the drain pan is totally dry, if dry, the drain is surely clogged.
good luck
Jul 22, 2014 | Refrigerators
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water from freezer compartment collecting at bottom of frig; under veg. drawers.
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water2_bing.gif in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain2_bing.gif wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running2_bing.gif into the drain hole...Please feel free to comment again if you have any other question. Mike
Nov 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My frezeer side has water leaking out and freezing in the bottom of the freezer
remove food
clean/defrost ice built up inside freezer at bottom of evap coil tray where water leaks down in a defrost cycle at back of freezer.
clean the drain line, find it under the fridge it drains into a pan, then blow back up though it.
Oct 02, 2009 | Frigidaire FRS23H7C Side by Side...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Side by side leaking water from under freezer side
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint HSS25GFP Side by Side...
Kenmore Fridge: 44103 side by side: I keep finding a
Sep 15, 2009 | Kenmore 44103 Side by Side Refrigerator
Water is pooling under the veggie bins- watere even came down via freezer door gasket to the floor. I have been noticing water in the right meat bin and in veggie bin, and under them for 2 weeks. most of...
Sep 12, 2009 | Liebherr European Right Hinge Fully...
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
109 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
