Question about LaCie 2big Network (2-disk RAID) (301257U) 1000 GB Network Storage Server
Red light won t go away on LaCie 2 big Network
In a nutshell, I've installed new drives onto LaCie 2 big Network but were formatted via my MAC thru disk utilities prior to and I can't seem to bootup nor reset successfully to access thru the network. What to do?
4 Suggested Answers
beast_b9
  • 113 Answers
SOURCE: WIndowx XP can't see my LaCie Big Disk 3TB
did you checked disk management? is it formated to basic or dynamic?
Posted on Jul 10, 2009
SOURCE: Lacie 2 big does,nt boot
Hmmm, reseting worked on mine. Identical symptoms except light stayed blue, not red. Unable to power down.
Before trying to get the drive working I got the data off using the procedure in the second post of this thread:
http://www.linuxforums.org/forum/peripherals-hardware/126831-reseting-lacie-2big-network.html
You need a linux system running. Maybe a live cd will do. I installed on an old IDE drive I had.
I then rest the decive using this procedure from Lacie and my drive is working again. Worthless though, because I can't trust it.
The procedure below will reset the 2Big Network to factory settings:
IMPORTANT NOTE: Following the procedure below can ERASE ALL DATA on the drive. Prior to following these directions, verify important data is stored securely on a different storage device.
Switch the drive OFF. Once it has shut down, ensure the power switch remains in the OFF position.
If the drive is in the SAFE mode, move the RAID switch to the BIG mode.
PRESS AND HOLD the button on the front. MOVE the power switch to the ON position. The light on the front of the drive will start blinking.
Once the light stops blinking, RELEASE the front button.
When released, it will begin BLINKING AGAIN. When it stops, PRESS AND HOLD the front button. The light will begin to blink again.
When the light stops blinking, RELEASE the button. The drive is now resetting itself. Switch the RAID selector back to SAFE if desired.
To restore data if it was lost during the process, recreate the shares and users on the unit prior to the reset. Any firmware updates applied will need to be applied again.
Posted on Oct 24, 2009
  • 34 Answers
SOURCE: windows vista is not detecting lacie network space
In your office network, for sure, you have a DHCP server who gave the IP addresses to all devices for that network and this seems to be the reason for why you could see your NAS. On home, you also need a DHCP server. You don't say anything about you home network. The best idea is to just make a temporary network with 2 devices: your computer and your NAS by connecting the NAS directly to your computer's network adapter, set the IPV4 IP for that adapter to the same class addresses as your NAS was set by default (usually NAS had "192.168.x.y" where "x" could be 0, 1 or 2 "y" could be any value between 1 and 254, but mostly, 1) and try to access it via http to manage him (need a user name and a password). For NAS default address and username and password, consult NAS user manual. Access it with from your preferred browser using: \\192.168.x.y
Once you gain the control, cut off his DHCP service and tell him to accept the IP address from the network defined DHCP. (btw: one normal DHCP server is allowed on one network! Cascaded DHCP also is allowed, but it's a little bit complicated)
Posted on Jun 25, 2011
LaCie 2big Triple - I replaced one drive, but capacity is wrong
Most likely the problem you are encountering is due to the RAID mode the device is set in. Most RAID arrays utilize multiple drives of the same size, or with drives of differing size, they just use a portion of the largest that matches the smallest drive. When the device rebuilt the array it partitioned off a portion of the 4tb drive of the same size as the existing 500gb drive. If you want to use full capacity of both drives you would need to use JBOD mode, which just strings the disks together into a storage pool using all available space. This won't offer the data redundancy of RAID1 or speed boost of RAID0, but should allow using full space.
Backup any vital data before doing anything, then look for a switch on the back. Rather than RAID0 or 1 the options may be labelled Safe or Fast, but JBOD is usually still labelled JBOD, or sometimes Big. You can try just flipping the switch to JBOD and seeing if it rebuilds to use all space. If that doesn't work you may need to remove the 4tb drive, connect it to a different system and erase it to get rid of the 500gb partition, then with the Lacie set to JBOD reinstall the 4tb drive so it will add its full size to the array.
The safest option though would be to buy another 4tb drive, backup all data and install both 4tb drives with the device set to RAID1/Safe. You would only get 4tb of total storage, but it would mirror the data on both drives so if one fails the other will still have your data. With JBOD you won't have any auto-backup. If a drive fails the data on it will be lost.
Jan 21, 2014 | LaCie 2big Network (2-disk RAID) (301257U)...
Setting up external storage without losing hard drive info
Likely the drive came formatted for a PC; also likely that the existing data is PC based.. Reformatting the drive for your Mac (a good thing to do) WILL erase the existing data, but you may not need it...
If you want to save it anyhow, just drag-and drop whatever's on the Lacie (before formatting) to your desktop (maybe in a new folder if you'd like).
Then format the LaCie for the Mac (with journaling is best) and once done, you can drag the stuff you put on the desktop back onto the hard drive.
Hope this helps
Nov 30, 2013 | Apple iMac Computers & Internet
My Lacie isn't letting me move files onto it. I need to move movie files over from my mac to the Lacie, but it's not working. I had added .wav files a few months ago, and those are accessible, but now that...
did you use your drive with a PC too?
What you describe is commonly linked to a drive formatted as NTFS (a windows partition format) which is read only on a plain MAC system. There are add ons you can install on your MAC to make NTFS writable. I can direct you to one if you need.
Another possibility is that your drive is formatted as MS-Dos (FAT32) which is read and write enabled for both PC and MAC, but it has the negative aspect of limiting file size to 4GB. So in your case, maybe your movie files are larger then 4GB and your drive is formatted Fat 32.
To verify the format of the drive, go to DIsk utility, select the LaCie drive and read the information that shows at the bottom of the Disk Utility window.
Regards,
Jan 10, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
Hallo, I have a LaCie Grand 1 TP external harddrive. I cant work in mine hard drive. I cant throw anything away i cant rename documents or put new ones on it. Some background info A few months...
Hi
you may face this issue because of differences between mac and windows file systems/partition table and security attributes that may disallow any further changes.
1-try to connect you HDD to a windows Computer and Backup all your files before loses any data(use more newer version of windows like windows 10 build 1709 windows XP is old/out of services and has many problems)
2-after a full backup in windows try to connect your HDD to your mac and format it via your MacBook
3- after formatting your HDD try to reconnect your HDD to windows and copy your files to HDD(windows has a compatible file systems that could read/allow/write mac file systems/partition and its attributes)
4-enjoy
best regard
Sep 27, 2017 | LaCie Grand 1 TB USB 20 Hard Drive
Cannot detect the lacie 1tb exreme big disk
Hi there!
Same issue here
Running win XP on my laptop and I have my LaCie NAS on my network and was working fine 'til today.
Issue: unable to access my LaCie NAS
troubleshooting done:1- rebooting NAS 2-power cycling the whole network 3- also tried accessing NAS from a Mac Book (used to be able) 4- nable to ping it by name or by IP
I had one my NAS's shares mapped to Y:, Now I can see the share from my network places but when I go to map network drive the Y: is no more assigned to that share.
My next move would be to re-install the NAS but I want to know and make sure that this will not delete what I have on that NAS.
Thanks to anyone that would jump in and give a hand to a desperate novice in Networking
Sep 30, 2009 | LaCie Big Disk Extreme (300797U) 1000 GB...
Sep 02, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
Jul 10, 2009 | LaCie 3 TB Biggest Quadra External Quad...
Lacie Big Disk Quadra 3TB won't work with xp-32bit
One way around is to install Mac Drive on your system. First you format your hdd in HFS+ on a mac platform, with any size you want.Then, after you installed Mac drive on your PC, it will work.
Jul 01, 2009 | LaCie 3 TB Biggest Quadra External Quad...
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
How to i reformat a lacie 500gig external hdd
The Mac OS can't natively write to NTFS (it can write to FAT32 however). But if you install MacFuse followed by NTFS 3-G on OS X then you'll be able to write to your NTFS drive.
Oct 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie 2big Network (2-disk RAID) (301257U) 1000 GB Network Storage Server Logo
3,549 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
