Need location of the usb 3.0 ports on aspire desktop model number am3470g-uw10p
SOURCE: Year old desktop usb ports went dead. Are powered
If multiple USB ports don't work at the same time, the problem could be the USB device you are using or the USB controller. If the controler, go into Device Manager and see if any problems (? marks). If no problems, right-click on the USB Controller and update the driver. If ? mark, contact FixYa again for further help. Good luck.
SOURCE: I have an Acer Aspire E380 desktop. Does it
It should not matter as long as the antenna is not surrounded by metal.
SOURCE: connecting dual monitors to an acer aspire m3470g
What type of device did you use to connect the two monitors to the computer? Is there a switch box to select which monitor you want to see?
SOURCE: aspire m347og keeps showing no signal when i turn it on
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". When the desktop comes up go to the link below and download the correct vga driver and install it:
http://support.acer.com/us/en/product/default.aspx?modelId=4037
SOURCE: Acer am3470g turns off unexpectantly
Bring it back where you bought it. My first idea is an overheating problem from power supply or CPU.
