Question about AOpen Mice: R-25W Wireless Mouse (MOUSEA25W)
Battery door for Microsoft Wireless Presenter Mouse 8000
I have the same problem. I broke the battery door when replacing the batteries and cannot find where to get a replacement door without replacing the entire mouse.
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Mouse problem
Update and install the newest hardware drivers from the Microsoft site. This should correct your problem. Yes, I know it will work Plug & Play, it just doesn't work properly. The other issue is batteries... use the most expensive batteries you can afford and never rechargeables as the voltage is less 1.25 V vs. 1.5 V.
Aug 27, 2012 | Microsoft Wireless Notebook Presenter...
Microsoft Wireless Notebook Presenter Mouse 8000. I am in need of a battery door
you can try doing a search on one of them auctions sites. its pretty hard to find just the battery door anywhere else. good luck
May 03, 2011 | Microsoft Wireless Notebook Optical Mouse...
Wireless Notebook Presenter Mouse 8000 need a battery door
You probably cannot just buy a battery door for a mouse. Try tape ;)
May 03, 2011 | Computers & Internet
Ms 8000 mouse pairing code
You choose your own code. It's a keyboard right? So it has numbers on it...and an Enter key.
1. Press and hold in the small button next to Bluetooth symbol under the keyboard for 5 seconds. The charge indicator lights at the top of the keyboard should alternate flashing red then green.
2. Search for Bluetooth devices on the devices you wish to connect the keyboard to. The Keyboard should be listed there.
3. Enter a code of your choice into the device you are paring the keyboard to and submit it. I used a 4 digit number which worked without a problem.
4. Type the same code and press Enter on the Microsoft Wireless Entertainment Desktop 8000 Keyboard.
The keyboard should now be paired with your device.
Good luck, - GregAndo
Jan 29, 2010 | Microsoft Wireless Entertainment 8000...
Replacement parts?
Apr 23, 2009 | Computers & Internet
Microsoft Mobile Memory Mouse 8000
Good Morning:
Hope that you are wellJ
Not the battery because the Battery Status LED Indicator glows red when the battery is running low. The green light indicates that it is charging.
If I can be of further assistance, please let me know.
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful week.
Oct 01, 2008 | Microsoft Wireless Mobile Memory Mouse...
AOpen Mice: R-25W Wireless Mouse (MOUSEA25W) Logo
337 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
