Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Eos 300 D
Shutter stays shut and will not open until I blow into it
    Sergeant:
  • 321 Answers
Require service or check speed of ur shutter 125
Posted on Jun 18, 2009
Regardless of lenses,and batteries, cf cards, flash and exposure settings, when the fire button is pressed there is a small "click" and the camera freezes-no picture none of the exposure settings...
A few suggestions: The mirror lock up function has been activated. The sensor cleaning mode has been activated, doing this the camera as soon as you trip the shutter the mirror will come up and all other functions of the camera are inoperable. the mirror will stay in that position until it runs out of battery or you turn it off. The part you said about having to removing the battery doesn't make scents for this function though. Sensor cleaning is in the Custom Functions.
I know you said regardless of lenses and batteries how long do you wait before shutting the camera off and removing the battery? I know that's a question and we aren't suppose to answer a question with a question but the reason I'm asking is that the Canon 40D has a long 30 second shutter speed and a "bulb" setting. It is possible that the camera has been set to "AV" and the shutter is timing out, OR it's been turned to BULB and that mirror will stay there until the camera battery is dead before it drops. Couple things to check out before the next thing I'd think about is the amount of shutter actuation. The Canon 40D has a shutter good for 100,000 clicks/actuation. Sounds like a lot but if you are doing time laps or extended video it's very possible to blow the shutter out of these.
Dec 10, 2010 | Canon EOS 40D Digital Camera
Shutter sticks
Does the light flash for 10 seconds, with a series of beeps getting faster before the picture is taken so you miss the shot, or are you saying the shutter stays open for several seconds giving you a whiteout picture?
If the former, then the self-timer is on. Press the button on the back of the camera to the right of the displays just under the AV button. The display icon will change from :-
Hand sweeping round clock = self timer mode
Simple square = single shot mode
Stacked squares = multi shot (keep finger pressed to keep shooting)
Feb 13, 2009 | Canon Digital Rebel / EOS-300D Digital...
Occasionally while shooting in auto/portrait my shutter will stay open for 1 second or longer, for no reason
Have you tried to reset the camera and reboot the firmware? I had that problem with a friend's camera and it simply worked.
Other thing is: are you using the original battery or a third party battery? sometimes bad quality batteries are creating such a problems like shutting down the camera, shutter lags...
I hope it helps, if not let me know
Nov 03, 2008 | Canon EOS 40D Digital Camera
Shutter problems
I am having a similar problem with my eos 100QD.
shutter opens, then stays open until I depress the shutter switch again.
Sometimes about half my photos are lost on a roll, but the other photos are fine (as would be expected from how the film is wound). This problem looks like it's caused by the shutter mechanism failing, a common problem with older camera and one that is often more expensive to repair than it is to replace the body.
May 25, 2008 | Canon EOS Rebel GII with 35-80 lens 35mm...
Rebel 2000 went retarded
I got a Rebel 2000 off ebay, and it had the same problem. The Shutter wouldn't open, it showed dead batteries, and the mirror hung until I pressed the shutter button or changed modes.
After a good deal of surfing, I found that the most likely reason was a sticky/oily shutter
(http://photonotes.org/articles/oily-shutter/).
Since I didn't have much $$$ invested in the camera, I tried cleaning the shutter curtain with Qtips and alcohol. After a little cleaning, the shutter started to move. After a lot of cleaning, the shutter moves freely. I ran a roll of film through it, and it seems to be working just fine now.
Feb 27, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
SHUTTER JAMMED SHUT ON CANON EOS 5D
It would seem this problem has frustrated other users, read this thread on photo.net
Oct 22, 2007 | Canon EOS-5D Digital Camera
Battery problems
Check the battery contacts inside the camera. Use a strong light, and if you see corrosion (black or greenish areas) on the contacts, rub them lightly with a pencil eraser until they are shiny.
Apr 05, 2007 | Canon EOS-1V with 28-105 and 100-300 lens...
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
