Question about Sharp AR-M237 Copier
Ar-m237 copier, getting black line thru all copies, cleaned, is this a drum issue? only 25000 copies on this unit how do you access drum and corona wire?
    Scholar:
  • 175 Answers
A line could be anything from charge unit dirty, a rotational line on drum or possibly a fuser roller that has a line worn into it. Question? Are we talking a straight uniform black line or is it irregular fuzzy line that changes some? If it's fuzzy, probably charge corona wire or grid dirty or needs to be replaced.
Posted on Jun 29, 2009
    Problem Solver:
  • 5 Answers
U clean main charger then fix new drum and blade
Posted on Jun 16, 2009
When pages are printed they have horizontal black lines across them
you need to clean either your drum or you corona's thes are the little wirespciking up access toner
please clean your drum with a dry tissue
also clean the corona's with a dry tissue
that should get rid of the issue
if not your drum need replacement
cheers
rene
May 28, 2011 | Dell Printers:Dell MFP Color Laser 3115cn
Copy quality from my sharp AR 275 copier keeps fading away. I have replaced the drum. I cannot locate the corona wire. where is it located.
No corona wire is there on this model, you can find one saw teeth like portion inside the main charger it serves the purpose of corona wire you can find the charger assembly on the drum unit, you try to clean the charger assembly by washing it and drying it buy the sun light, better to replace the maincharger, drum, cleaning blade, and developer together. Rate this and vote for this .
May 18, 2011 | Sharp AR-275 Copier
Vertical Lines through incoming faxes and copies.
Sometimes you may see vertical streaks/black lines
on the faxes you receive. Either your FAX/MFC's
primary corona wire for printing may be dirty, or
the sending party's fax scanner may be dirty. Clean
your primary corona wire (see pages 13-18), or ask
the sender to make a copy to see if the problem is
with the sending machine.
Cleaning the Drum Unit
We recommend you place the drum unit on a drop cloth or large piece of
disposable paper to avoid spilling and scattering toner.
1 Carefully turn the drum unit upside down.
2 Clean the primary corona wire inside the drum unit by gently sliding the tab
from right to left several times.
3 Return the tab to the Home
position (  ) before
reinstalling the drum unit.
Jan 31, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
My ar275 copier has a problem with the developer unit. the developer leaks out when the machine is working. what is the remedy
The corona in the drum unit might be dirty which causes an arc that pulls the developer out, Take drum unit out and there are 2 black tabs with a screw in them, Remove the two screws and remove the corona and clean. Be very carefull not to scratch or touch the drum.
Sep 09, 2010 | Sharp AR-275 Copier
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
The copies comes out totally black
H2 00 Thermistor open, your fusing unit needs to be serviced (cleaned or replaced)
The black copiers can be a number of things a few things to check and what the remedy could be;
  1. Open the right door, if you notice a lot of toner/developer spilt then you could be having a charge corona short (built onto the drum unit) clean corona
  2. Open the right door, if you drum (green or blue cylinder (depending on brand of drum) under your fuser) is coated with toner (should be all green/blue) then you could be having a drum short, replace drum unit for this.
  3. Open the right door and on the door towards the bottom is a metal unit with a white guide built on it (transfer corona) if there is a lot of toner/developer in it (looks dirty) then this needs to be cleaned or re-built.
  4. You also could be having a board issue causing the black copies.
Mar 26, 2009 | Sharp Office Equipment & Supplies
Sharp ar-m237 copier
Direct light can effect the copies. Your unit may also need developer as well. If the developer is low or gone out of the unit, light copies will appear as well.
Jul 10, 2008 | Sharp AR-M237 Copier
How do I change the drum on a Sharp AR-M237?
Hi, i assume you have a drum to replace it with?. Can't really clean them as they are very sensitive. Why does it need changing, your copy quality is effected?. It is a faily straight forward procedure.
Let me Know
Andy
Mar 04, 2008 | Sharp AR-M237 Copier
you check the optical unit and laser unit glass and cleaning. the next check drum counter process unit counter.
May 10, 2007 | Sharp AR-M237 Copier
Sharp AR-M237 Copier Logo
418 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
