Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
Need new cartridges for shower and tub/shower...but which one???
The house was built in '72. Both the shower and the tub/shower have Moen Single Handle faucets with a big round chrome plate. The tub/shower 'diverter' is not on the tub spout, but a little metal push/pull on the round plate itself. Both diverters get 'secured' by a thin brass horseshoe-like clip that slides vertically in front of the cartridge. The push/pull mechanics are now so stiff I can barely get the water on, and I have to POUND on the big round knob to turn it off... MY PROBLEM: I don't know which cartridge to buy...is it the 1200? the 1225? the 1222? In order to compare at the HomeDepot, I'd have to turn all of the water off to the house, remove the cartridge, run to the store and HOPE they have a replacement. Can you help me find the right cartridge(s)???
Thanks,
Gary Gray
  • geeyesgee Jun 17, 2009
    Although the response I received was good information...it did not really address my question...which was: WHICH CARTRIDGE(S) SHOULD I BE LOOKING FOR?? I guess I need an old Moen expert..I already know how to remove a cartridge, and I have the Moen 'tool' for doing it. I just need new cartridges that will FIT, and I need new brass "securing clips" as well. As I said in my original question, I have faucets that have a large (2") knob that you pull out to get the water on and then twist clockwise for cold and counter-clockwise for hot. When done you push the knob back in towards the wall. The hot/cold aspect works fine...it's the push/pull that is becoming impossible for anyone under 200 pounds. Can anyone help? Thanks. Gary
    I pay $10 for a WEBSITE ADDRESS?
    Neither of you actually answered my question.
    Good luck.
    Genius:
  • 1,847 Answers
Here is all the information you need ...
http://www.moen.com/buyMoen/buyparts/index.cfm
Just select the option in the middle of the screen, like ( 1. Is your faucet in the Bathroom or the Kitchen?)
You can order from this site online else call
Call: 1-800-BUY-MOEN (1-800-289-6636)
8:00 am to 8:00 pm Monday thru Friday
8:00 am to 6:30 pm on Saturdays EST
Closed on Sundays and all nationally observed holidays
Thanks
Kindly rate the answer
Kevin
Posted on Jun 17, 2009
  • 315 Answers
I think you have a sick shower. Actually, what you have is a common problem that afflicts many showers each day: the dreaded shower cartridge.
A shower cartridge is about the size of a roll of nickels, and has holes and rubber washers all around it. It will take about 30 minutes to fix, but will save lots of water as a result.
If you have to pull out the knob to start the flow of water, the replacement cartridge will cost about $15. If you simply turn the knob from side to side, you have a posi-temp cartridge, which costs about $45. You can find replacement cartridges at most home centers, but if they don't have your particular type, try a plumbing supply store.
Now, let's get to the repair. First, shut off the main water supply to the house. Open a faucet to let out the water pressure, then move to the shower.
Using a small, standard screwdriver, gently pry off the shower knob cover. Under this cover is a screw that holds the knob onto the cartridge. Remove the knob.
Next, you'll find the valve body, which covered by a decorative escutcheon. Remove the escutcheon by gently pulling it straight out.
A retaining pin holds the cartridge in the shower body. This pin will have a nub sticking out of the top of the shower body. Grab a pair of pliers and pull it straight up.
The only thing left to do now is remove the actual cartridge. I recommend that you get your hands on a cartridge remover, which costs about $10. You also can try your luck with pliers, however, the cartridge- removing tool is made just for removing cartridges.
Place the larger, hollowed end of the cartridge remover into the shower body and over the old cartridge. Tighten the screw on the end of the tool. This screw fits into the hole where your shower knob was, and it locks the tool into the cartridge. When the ears of the tool are engaged with the ears of the cartridge, turn the tool (and consequently the cartridge) to break the cartridge free from years of torment. The cartridge will pull straight out.
Take the old cartridge with you to a plumbing parts store or a home center to find an exact replacement.... As you have a very old system you might be needed 1222 Posi-Temp.
Install the new cartridge simply by pushing it into the shower body with the ears in the 12-and-6 position. Push it in far enough so that when you replace the retaining pin, it slides completely into place and locks the cartridge in place.
Next, turn the water back on and make sure there are no leaks. Replace the escutcheon and the handle.
Now, test to make sure that the hot water side is hot and the cold water side is cold. All you need to do is remove the shower knob, take a pair of pliers and rotate the stem (the part of the cartridge that the shower knob screws into) 180 degrees. The cartridge stays put, but the stem is free to rotate. It's the knob and the escutcheon that restrict the movement of the stem.
Best of luck!!
We had both the shower and the Bath tub remodeld and installed new Moen faucets with a single knob that turns right to left to open. All was fine for a couple of days but all of the sudden they startd...
You need to install a new moen cartridge its a single handle posi-temp cartridge you should be able to get 1 for free if you are the original owner by calling 1-800-buy-moen more than likely when soldering in the new valve a little bit of solder broke free into the cartridge or hard water. When the water gets turned off and then turned back on it can break free alot of particles that can get jammed up in these cartridges or any fixture for that matter you will need a cartridge puller to perform this job with ease.
Aug 27, 2011 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
How do I repair a leaky Moen faucet handle. When I
It needs a new cartridge. Moen gaurantees most of their products for life, so if you have the original instructions check for contact info. They'll send you a new cartridge for $0.00
Jan 13, 2010 | Moen & One Handle Tub & Shower Faucet
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
New house . tub wont turn off. water has a steady
The plumber soldered in the faucet without removing the cartridge, the o-rings are melted. Have the builder replace the o-rings.
Mar 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
166 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
