Question about Kenwood KCA-BT100 Wireless Headset
Address Book - Manual entry
Is there a way to manually add phone numbers to the address book ?
Re: Address Book - Manual entry
I have just worked it out after numerous attempts!!!
1) Pair your mobile phone with the KCA BT100 (Passcode 1234)
2) Disable the "handsfree" option on the mobile phone for this pairing
3) Select the contact you want to send, bear in mind that the maximum you can send is 300!
4) 'Beam' the contact and your phone will search for bluetooth devices
5) Select the KCA BT-100 and press send/enter
A few seconds later the contact will be sent.
Once you have sent all the contacts you wish to send, turn off the car. Enable the handsfree function on the pairing, when you view the telephone screen you will see that the phonebook option has now been highlighted and you can select from the contacts you have just enetered!
Posted on Jun 18, 2008
  • 4 Answers
In reference to solution 2 if you mark all entries in your contacts then send them via blue tooth buisness cards they will transfer enmass but you have to do what kev says first
Posted on Jun 08, 2008
Do you know how to delete a contact once you have added it?
Posted on Feb 11, 2008
You have to first pair your phone with the head unit. After that is successful, unpair it on your phone, but keep the bluetooth on. Go to individual contacts, and select "send using bluetooth". If the contact transfer is successful, the phone number will appear in the Phone Book list on the head unit, the next time you pair it.
Posted on Dec 16, 2007
0 characters
3 Points
I have no idea what standby looks like; but I can't access the phonebook; I see the symbol, but nothing happens when i press it; I have successfully linked my cell and downloaded the phonebook from cell;...
A qualified person will have to remove the back (and circuit boards if necessary) to get to push buttons. Check for bits of plastic or something stuck between push button and circuit board. Check for corrosion on circuit board or missing /misaligned switch pieces.
Oct 29, 2013 | Uniden D3588-2 Corded / Cordless DECT 6.0...
Can't transfer Blackberry's 8100 phone book contacts and associated photos to it.
Here is a link for a manual, if you do not already have one.
and another for bluetooth products etc.
Feb 14, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Cant open any messages sent to my phone inbox
You need to check the settings then .....
Message > Menu > Message Setup. Fill in the required and you should be away.
Master Clear and Master Rest get rid of all your pictures, ringtones, videos and address book
so beware of this !
Aug 06, 2009 | Motorola Mobility HS850 Consumer Headset
I have LG4015 havent used it for about a year but want to use it again instead of getting new one this one I only used it for a couple months before now says restriction code needed.
Hello wleeee
I'am having problems setting up am address book on my used LG4015 cell phone.
I was given a website to go to , at first it seemed like it would work, then my phone
went back to it's original problem. Is it possible that you will send a Manual/ Directions
to my E-mail???
I would really appreciate it very much- if the answer is yes my E-Mail is
Respectfully Submitted
Ms. Linda Archibald
Jan 12, 2009 | LG C1300/L1200/4010/4050/L1150/G4015...
Blueant z9i headset cannot locate push server
Often this is an issue with the phone pairing as a "handsfree" rather than as a "headset". Try resetting the Z9i (push Vol Up, Vol Down and Blueant buttons at same time), then re-pairing ensuring you chose "headset" mode on the Curve.
Dec 30, 2008 | Blueant Z9i Bluetooth Headset
Maual for Motorola H350 bluetooth headset
Hi - You can download the manual from the link underlined in blue below:
Motorola H350
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 18, 2008 | Motorola Mobility H350 Wireless Headset
Transfering contacts from phone to KCB-BT100
yeah, this sucks, but a guy at Car Toys said that the Kenwood's are notoriously difficult when it come to the Bluetooth... through your phone, you have to disconnect from the BT100, but keep your Bluetooth "on", and then send each contact one by one. Talk about pain in the ___, but that works.
Now, my problem is that the address book comes and goes; sometimes it's available, sometimes not.
Feb 20, 2008 | Kenwood KCA-BT100 Wireless Headset
Motorola V360 on Vodafone pay as you go
chuck that phone away it always has that issue-
Nov 21, 2007 | Motorola Mobility T-MOBILE V360 Flexible...
Need PIN for Just wireless bluetooth
I threw away my instructions for my bluetooth just wireless model #bt-5 and I cannot find the pin number i need to add to sinc up my phone, can you help?
Sep 23, 2007 | Just Wireless HandsFree Earboom Silver...
How do I block out specific callers
There doesn't seem to be any feature in this phone which allows you to block a specific number, however, you can check under the settings -> Security -> restrict calls features, if there is any option to block a specific number. I could not find any 3rd party software which could enable this feature on this phone. You can also contact your service provider to block that phone number if 'someone' is really annoying you.
Mar 02, 2007 | Motorola Mobility Earwrap Handsfree For...
Kenwood KCA-BT100 Wireless Headset Logo
437 people viewed this question
Top Kenwood Headsets Experts
Timmy Cushing
Level 1 Expert
Cosma Papouis
Cosma Papouis
Are you a Kenwood Headset Expert? Answer questions, earn points and help others
