Question about HP PhotoSmart 7960 InkJet Printer
Printer keeps saying black/grey ink problem
I changed cartridge but cannot get printer to stop blinking
    Problem Solver:
  • 7 Answers
I think Cartridge is exhausted .. or less fit the cartridge in place.
I recommend ... Cartridge is to check .. if already in place .. or not ..
if not. please pas on the location of a place .. if need to clean the cartridge .. then .. pull the power the printer .. and then .. pairs again ..
I hope you can help.
Posted on Jun 16, 2009
My printer is not printing black only colours
there must not be as same as you are saying but it may perhaps happen that, live cartridge doesnt perform due to improper heating of that printer. its heating mechanism may have failed, go to its care center and get treated...
Nov 05, 2012 | Kodak ESP C315 Wireless All-in-One Printer
Just had new printer again kodak esp 7 and got same problem black ink cartridge not printing
are the ink cartridge you are using refurbished because sometimes the printer wont read them had a simular prob with my printer you might have to just buy new ones for it
Sep 30, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Mar 24, 2010 | Epson Stylus cx7450 All-In-One InkJet...
My printer keeps on blinking error for no ink and
If by "just changed the ink "you are trying to say that you have just recharged you printer's cartridge then don't put this question to yourself because this happens when the printer figures out that the cartridge is not original!
Dec 19, 2009 | HP DeskJet F380 All-In-One Printer
Will not print
“All lights blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
Dec 09, 2009 | HP DeskJet 920c InkJet Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
My printer says E 5
Try reseating the ink cartridges. The error references to either reseating or refilling the ink cartridges.
Since you have mentioned that it worked before with only black cartridge, try reseating both and check.
Apr 02, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Ink light blinking hp920c
Yes, sorry to say. The system uses all carts even to print in black.
Feb 13, 2009 | HP DeskJet 920c InkJet Printer
HP PhotoSmart 7960 InkJet Printer Logo
76 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
