Question about Nintendo Wii Console
My wiimotes don't connect to the wii at all
I want to play naruto really badly but none of my wiimotes connect at all please help im about to send my wii back please help
  • 104 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-73
Posted on Jul 22, 2009
    Problem Solver:
  • 8 Answers
Did you try syncing your Wii-motes? Take off the battery cap and push the red button there at the same time as the red button near the SD slot.
Posted on Jun 16, 2009
Can't add wiimote when playing Cabelas Big Game Hunter 2010
If it is a one player game the wii disconnects other controllers to save battery. Some games say 2 player but in the fine print you learn that it is only online (with other wiis)
Jan 05, 2014 | Activision Cabela's Big Game Hunter for...
My wii will turn on, but nothing shows up on the screen
Good news i had same problem and what i found out was that the wii bricked up an easy fix is to unplug ur wii from all cables then after 3 minutes plug only the power cable and see if ur wiimote connects but before dat remove sd and usb if the wiimote connects but u getno display then u have t afjust ur screen resolution hope this helps :)
Jul 03, 2012 | Nintendo Wii Console
Wii controller won't work with gamecube game in wii console
Gamecube games don't have the proper coding installed on the discs in order to receive commands from the Wiimote. You'll have to have a Gamecube controller to play Gamecube games even on the Wii console.
Nov 23, 2011 | Nintendo Wii Console
My wii remote would not work so i bought a new wii wireless sensor and it still does not work can you help please
Have you checked the battery in your Wiimote? It seems like a very basic thing to do, but sometimes the wiimote might not hold a charge if you placed the batteries in incorrectly. If your Wiimote is showing a charge, then you may have forgotten to sync up your wiimote with your sensor bar.
  1. Open the battery door to your Wiimote
  2. You'll see a red button on the bottom of the opened hatch, it says SYNC.
  3. Press that and the sync button on your Wii.
If that still doesn't work, check the connection of your wii sensor cable to your wii. Try pushing the cable in securely.
Mar 08, 2011 | Nintendo Wii Console
Wii remote not sensing
ahh. First im going to go threw the obvious:
1) Make sure that you see that little blue light on the WiiMote.
2) If you don't, try to sync it to your Wii.Press the red button under the little door on the front of you wii, at the same time press the button on the back of the wiimote.
3) make sure there are good battery's in it.
If that doesn't work go to this link: http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Feb 16, 2010 | Nintendo Wii Remote Controller
Even with new batteries in the wii remote,when i turn on the console,the screen comes up that says "press A button",,,,but nothing happens,the sensor bar is firmly secure but still nothing happens,its very...
Is it a Wii game? Gamecube games aren't compatible with Wiimotes. Otherwise, Check the lights on the Wiimote, Are they on? If not, You could have a battery problem, Or your Wiimote could be broken. Make sure the Wiimotes are connected, See your manual for info on how to Sync.
Oct 27, 2009 | Nintendo Wii Console
Nunchuck wii problem
Most likely not a fault with either. Try not touching the nunchuk while the game is powering up, as moving the joystick while the game is powering up can cause these issues. If the problem is still happening, click the Wii Home button and open the Wii Remote Settings at the bottom of the screen. Choose the option to reconnect the remote, and then try again. If this doesn't work, ai am not really sure what is the issue. You may need to send to NOA for a checkup.
Mar 13, 2009 | Nintendo Controller add-on Nunchuck for...
Wii remote won't work. Just lights up
pair the wiimote with the wii. open the slot where the sd card goes press the red button then open the wiimote and press the red button right after
Feb 25, 2008 | Nintendo Wii Console
Problem with wiimote
the problem could be uv light, if its daytime make sure all the blinds are closed no extra lights are on near the sensor bar. if there is a glare on the screen at all it could be reflecting light to the wiimote as well. I've had that problem before myself, if that is not the case try moving closer to the sensor bar, make sure the sensor bar is connected correctly and then go to the system settings menu and calibrate the wii sensor bar and adjust the sensitivity, make sure you are not sitting at a wide angle from the snesor bar either, you can tip the sensor bar left and right in order to allow yourself a wider angle. also avoid using the nyko wireless sensor bar, it has a shorter range than the wired one that somes with the wii, mine came with a wireless on(used) and i just got a wired one and now it works much better. well I hope you find this info at least a little useful.
Feb 15, 2008 | Nintendo Wii Console
Wii sprts bowling
All my friends have a bad habbit of doing this. Watch the instructional animation when it shows the instructions. This will help you. hold up wiimote hold B, keep holding B and swing back, then swing forward and release B button.
Dec 27, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
