Question about Whirlpool LHW0050PQ Front Load Washer
Washer drum appears off-kilter, loud knocking noise during spin
I washed a rag rug that became very heavy and during spin I thought the washer would fly through the wall. I turned it off but the washer drum now appears off-kilter as if it got knocked sideways inside the machine. Light loads spin with little or no noise, perhaps one or 2 knocks against the side when it goes into the final fast spin, but heavier loads make the whole machine go crazy. How do I fix this? Thanks!
jsrock516
  • 5911 Answers
SOURCE: Knocking Whrilpool Duet
The "cleats" inside the wash tub are actually called "fins". If they are loose try tightening them to see if the sound goes away. You should be able to tighten them from inside the wash tub. Some models have mounting screws that are accessible from inside the wash tub. However, if your machine is knocking like you say it is, it could be sign that one or more of the mounting shocks under the wash tub could be bad, the rear tub bearing could be going bad, or the drive pulley could be cracked or warped. Remove the lower kick plate and watch the shocks during the spin cycle. The shocks should vibrate some, but should not be excessive to the point that it causes an unbalanced spin. To check the drive pulley, remove the 3 screws from the washer top in the rear of the machine. The top should slide back some and then lift off. Watch the drive pulley behind the wash tub during the spin to make sure the rotation is smooth and even. Sometimes one of the arms on the pulley can crack or become bent and cause the pulley to wobble. More than likely, though, the drive belt would slip off. I have also seen where the hole in the center of the drive pulley starts to "round out". The hole is not perfectly round and has to flat sides. Sometimes over time the drive shaft will start to slip around the flat sides, causing the pulley to rattle during the spin cycle. If the rear tub bearing is starting to go, the washer will be very noisy during the spin cycle, and you may start to notice some stains on your clothes if the bearing seal has been breached. You can reach inside the wash tub with the unit turned off. With one hand, push up on the wash tub and release. If you can feel the tub moving up and down (even the slightest) this could be a sign that the bearing is worn out. Now this should be a noticeable metal on metal type feel. Not the normal motion of the wash tub moving up and down from the motion of the shocks. The tub bearing is not a cheap (or easy) fix. The entire back section of the rear outer tub shell has to be replaced, because the bearing is molded into the plastic. Check all the easy things first. Let me know if this helps.
Posted on Jun 28, 2007
  • 125 Answers
SOURCE: knocking sound
The spider on the back of the drum is most likely broken. The part should have a 10 year warranty. Labor should run 250 - 350, unless you call A&E, then it will be a lot more.
Posted on Jan 21, 2008
the_admiral6
  • 14 Answers
SOURCE: Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Posted on Mar 07, 2009
  • 6 Answers
SOURCE: Was washing my kitchen rug and on the rinse and
With the Door Lock display on (which is what the red key indicates), are you able to open and close the door?
If so, you probably have a defective door lock assembly. Try unplugging your machine for a couple of minutes and plug it back in to see if it resets itself.
Posted on Oct 10, 2009
TheMobilian
  • 8220 Answers
SOURCE: My whirlpool 3.2 cu ft washer is making a loud
screw%20removal.jpgUse a screwdriver to remove the screws holding down the control panel,then swing it upwards.
Use a flat blade screwdriver to pop these Clips
Unplug the lid switch connection.
Tip the case forward and remove it.You will now be able to repair the washer! tip%20the%20cabinet%20forward.jpg" />
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 23, 2009
Testimonial: "Thank you so much, hopefully we can quiet this baby down."
Whirlpool Twin Thin Washer makes very loud noise on drain/spin.
Sounds like the bearing on the drum has gone , open the door and see if you have any play on the drum by moving it side to side and up and down good luck
Dec 13, 2017 | Whirlpool Washing Machines
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Fridgidaire Washer has a loud knocking noise during spin cycle.
You need to replace your washer, the Inner tub Spider broke.. I repaired mine, With me doing the labour, $285 just for the part alone. plus about 3 to 4 hours labour.
Mar 14, 2009 | Frigidaire FWTBB30DS Front Load Washer
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cycle
Most washer tubs are suspended by heavy rubber O-rings. These do fail with age so that the tub is not being held centered anymore. I suspect one of them has failed or come off during a severely unbalanced load.
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
670 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
