Question about Lenovo 3000 V100 Notebook
The system cannot find \windows\system32\config\system
Cannot start the notebook. Please help. Thanks.
  • 157 Answers
You need a windows xp cd. Easiest way is to do a repair install of windows xp however some programs will need to be reinstalled after that. If you are familiar with the command prompt then you can go into the recovery console and copy the windows\repair\system file to windows\system32\config
Posted on Jun 16, 2009
2 Suggested Answers
domotek
  • 591 Answers
SOURCE: window could not start because
First try to boot with a bootable Windows CD, log in a terminal session (command prompt) than perform a CHKDSK /R command, if it does not work try a WINDOWS REPAIR from the same bootable Windows CD... if you finally get it going you should scan the computer with a GOOD UP TO DATE anti-virus... (just in case)
Cheers!
Posted on Mar 25, 2011
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Saying:/windows/system32/config/system is missing or corrupted n i dnt now how to fix it wut link exactly do i have to download to my usb to fix it n wut r the steps?
Assuming it is windows XP here are the steps to fix that error:
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp
My YouTube Channel
Click Here Live Tech Support
May 03, 2013 | ASUS Eee PC 2G Surf Notebook
DELL 300M
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Sep 08, 2012 | Dell Inspiron 300M Notebook
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
Hp paviliondv2050us wont start
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
\Windows\System32\Config\System; Repair w/CD-ROM; NO CD-ROM
if you can get an external cd/dvd drive from a friend, then you could solve the problem.
other solutions would mean that you will reinstall windows again. This takes more time and has a few tricks to be done from a flash drive.
Mar 22, 2009 | Acer Aspire One PC Notebook
Windows/system32/config/system is corrupt
One of following will work:
http://www.help2go.com/Tutorials/Windows/C:%5Cwindows%5Csystem32%5Cconfig%5Csystem_missing_or_corrupt.html
http://www.techsupportforum.com/microsoft-support/windows-xp-support/312090-windows-system32-config-system-missing-corrupt-files.html
http://en.kioskea.net/forum/affich-22815-windows-system32-config-system-is-corrupt
http://support.microsoft.com/kb/307545
Mar 20, 2009 | Microsoft Windows 2000 Professional for PC
\windows\system32\config\system missing or corrupt
You can do a refresh of your Windows OS, if you have Windows XP. You need to boot to your XP CD and do a repair. This will only restore the Windows OS files and you will not lose your personal data.
This should help. please rate my response.
Feb 17, 2009 | Gateway MX6440 Notebook
Lenovo 3000 V100 Notebook Logo
167 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
