Question about Maytag MDB6650A Built-in Dishwasher
My GE Profile Dishwasher (Model PDWT480PSS) just stopped working.
Neither my wife or I recall setting up the delay wash cycle last night before going to bed (although I suppose it is possible the delay was inadvertantly pressed while loading dishes). In any event, this morning it was obvious that the dishwasher had run (still warm - light steam coming out when we opened the door this morning), but there were no indicator lights on the control panel. There is clean water at the bottom of the machine (more than just residue - it's a significant amount). I reset the breaker a number of times and verified that there is no leakage or water on the floor but the machine just won't work and no indicator lights come on. The machine was only installed 2 weeks ago and has been working fine until now. Any help is much appreciated.
catriver
  • 878 Answers
SOURCE: Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Posted on Oct 23, 2006
SOURCE: Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Posted on Mar 05, 2008
SOURCE: I can't get my dishwasher to start
Part Number: 99002254 you may need this part depending on model no
SWTCH-DOOR 99002254.jpg View Larger Image
Posted on Jun 02, 2008
SOURCE: Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
MNfisherman
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher lights up when Normal Wash is pushed, also heat dry - but when start is pushed all three lights (Normal wash, heat dry and washing) blink then go out and nothing happens. This occurred after a 2...
What is the make and model so we can better assist you? In the mean time shut power off to the unit briefly, then turn it back on and try a normal cycle. Will be watching for a make and model here.
Jan 20, 2010 | Dishwashers
Is this GE Profile dishwasher recalled?
No recalls on any GE Profile model dishwashers. (there may have been service bulletins, but no recalls) Also, you missed the first two letters of the serial number.
You can go to this web site http://www.geappliances.com/products/recall/ to find info on any GE recall.
May 07, 2009 | GE 25 in. PDW7380JSS Stainless Steel...
My ge profile dishwasher oveheated.
There was a recall on some GE dishwashers, but yours was purchased a bit before those affected. Just to be sure, go to http://www.geappliances.com/products/recall/dw07/ and input your full model and serial number (including the last letter of the serial number). Of the models affected by the recall, I've personally seen (and have photos of) one that burned, plus one that was close to it. Recalled ones can be updated for free, or if you decide to replace, qualify for a rebate toward a new GE dishwasher. (the recalled ones had problems with the wiring inside the door) If your model is not one affected by the recall, I would contact GE customer relations via their answer center phone (800-626-2005) to report this potential safety issue.
Feb 01, 2009 | GE Profile PDW9880NSS Stainless Steel...
Error code
you have set it to start after a one hour delay- just press the start delay button until it cycles through past 24h and you will get back to the immediate start mode...
Oct 12, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
GE Triton Dishwasher won't stop running
try to reset the circuit braker--remove all power.
Aug 27, 2007 | Dishwashers
Maytag MDB6650A Built-in Dishwasher Logo
140 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
