Question about HP OfficeJet 6110 All-In-One InkJet Printer
My HP 6100 series all in one wants to align cartridge
It fails to print faxes, but prints a list of recieved fax times and the self test report.
    New Friend:
Have a one year old H.P. 6100 printer and was working fine.
Don't know what I did ,but laptop&desktop are saying need allinment on head?
Posted on Jan 26, 2014
  • 72 Answers
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Posted on Jun 16, 2009
Error on hp j4680 image on fax send report is set to on
Sir/Madam
Solution one: Print a fax test
1.Make sure the product is turned on and correctly connected to the telephone jack.
2.Make sure that there is plain white paper in the input tray.
3.On the product control panel, press the Setup button ( ).
4.Press the right arrow ( ) to select Tools , and then press OK .
5.From the Tools menu, press the right arrow ( ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
6.Review the results of the test.
·If the test lists faxing issues and solutions, the fax test failed. Follow the solutions on the printed report to troubleshoot the issue. This report is specific to your product and faxing environment, so use the solutions on the report to resolve the listed faxing issues. Repeat the Fax Test after fixing the listed faxing issues to make sure the test passes.
·If the test does not list faxing issues and solutions, the fax test passed. Continue to the next solution.
7.Try to send a fax again. If the HP fax still cannot send a fax, continue to the next solution.
In case You Still facing Problem The Visit official HP Printer website Below URL Link On:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01555948&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3692888
OR
If you Still having Problem then follow Us On:
HP Printer Support
Feb 12, 2014 | HP J4680 Office Jet All-In-One Printer
How do I print the fax log?
Follow the steps below to print Fax Logs for already received faxes
  1. Press Setup , and then press 2 . This displays the Print Report menu.
  2. Press the Right arrow button to scroll through the following report types:
    • Fax Report Setup: prints the automatic fax reports as described in Generate reports automatically.
    • Last Transaction: prints details of the last fax transaction.
    • Fax Log: prints a log of approximately the last 30 fax transactions.
    • Speed Dial List: prints a list of programmed speed-dial entries.
    • Self-Test Report: prints a report to assist in diagnosing print and alignment problems.
  3. After the desired report is highlighted, press OK .
Also, Click on the link below for more information about Fax settings on your printer
Fax Settings
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | HP OfficeJet 6210 All-In-One InkJet...
How to turn fax send report on
the Officejet Pro 8500 Series can still do a fax confirmation page, you just have to set it up. Press the Setup button (looks like wrench), then 2. Print Report, then 1. Fax Confirmation. From there you can select to print it out on Send, Recieve, or Both.
Nov 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Hp office jet K80 recieves fax, sounds like it is printing but pages are blank
It sounds like an empty cartridge. check your cartridges, it may be time to replace them. You have to give more information like did you try a print test and if so did it print ok? have you tried to have someone send you a test fax from different numbers?
Jul 17, 2010 | HP OfficeJet K80 All-In-One InkJet Printer
Fax will not work at all. I have reloaded the software, unplugged and replugged everything, talked with HP(they want a fee to talk) When you turn it on, it is a "fax failure" message. Will not send or...
Try to Run Fax Test
Press the Setup button on front panel
Scroll to Tools - Press OK
Choose Run Fax Test - Press OK
It should print the Fax Test Report.. it will list you the possible cause why you are getting Fax Failure..
If it says Hardware Test Failed..do a Reset on the Printer ( Hard Reset )
this will printer reset the settings to Factory default like your rings to answer will change to default, Speed Dial list will be wiped off
Steps to do :
Disconnect the Phone cord from EXT 1 of printer
while the printer is on, Disconnect the power cord from back of printer. While holding the # and 6 Buttons, connect the cord back and release the buttons after 5-6 seconds..
go thru the alignment process and re-align the printer
Connect the Phone cord back and try to Run the Fax Test and check if everything passes in the list.
Jun 25, 2010 | HP OfficeJet 6310 All-in-One Printer...
When recieving a fax the print speed is at a snail pace. It takes for ever for the printer to print a page of the recieving fax.
try this and let us know. do fax diagonastics.
Test the fax setup from the control panel Follow the steps below to perform a fax diagnostics test.
  1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide .
  2. Make sure you have inserted the print cartridges and loaded paper before starting the test.
  3. Press Setup , 6 , and then 6 . This displays the Tools menu and then select Run Fax Test . The HP all-in-one displays the status of the test on the color graphics display and prints a report.
  4. Review the report.
    • If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
    • If the test fails, review the report for more information on how to fix any problems found.
  5. After you pick up the fax report from the all-in-one, press OK . Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test.
Accessing the Diagnostic Utility from HP Solution Center The fax Diagnostic Utility can also be accessed from the HP Solution Center software, by selecting the HP Fax enabled product in the drop down box, and then following these steps:
  1. Select Settings , Fax Settings & Setup , Fax Setup Wizard .
  2. Tab through the Fax Setup Wizard to get to the end of the process. This is a good opportunity to ensure that your fax machine is setup correctly.
  3. Click Click here to run the Fax Test . The HP all-in-one displays the status of the test on the color graphics display and prints a report.
Sep 14, 2009 | HP Officejet J5780 All-In-One InkJet...
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have the hp d1400 series...it wont print and its telling me i have an alignment problem..it all stemed from me changing my printer cardridge
Align the new print cartridge
  1. On the Windows taskbar, click Start .
  2. Click Programs or All Programs , click HP , and then click HP Solution Center .
  3. In HP Solution Center , click Settings , click Print Settings , and then click Printer Toolbox . The Printer Toolbox opens.
  4. Click Align the Print Cartridges .
  5. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and calibrates the printer.
  6. Recycle or discard the test page.
Mar 11, 2009 | Lexmark Office Equipment & Supplies
Officejet 7310 HP
Follow the steps below to perform a fax diagnostics test. 1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide. 2. Make sure you have inserted the print cartridges and loaded paper before starting the test. 3. Press Setup, 6, and then 6. This displays the Tools menu and then select Run Fax Test. The HP all-in-one displays the status of the test on the color graphics display and prints a report. 4. Review the report. * If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems. * If the test fails, review the report for more information on how to fix any problems found. 5. After you pick up the fax report from the all-in-one, press OK. Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test. If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
Aug 07, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
530 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
