Question about Canon i850 InkJet Photo Printer
Canon i850 printing but pages are blank
When I print a page it comes out blank. I have cleaned the printer heads and still not printing. What should I do?
  • 3 Answers
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Posted on Aug 02, 2009
  • 256 Answers
If your printer ink cartridges have ink in them but the printer is not printing, I would suspect the print head is clogged with dry ink. You can purchase print head cleaning solutions and try them or purchase a new print head. I do not recommend buying a new printer, your I850 uses unchipped cartridges which are inexpensive and refillable. Try http://officestoredepot.com/. I bought a print head for my Canon S750 and a 20 lot set of cartridges there and am very pleased. Use this as a start to hunt for print heads and/or ink Carts. Do your research and then make an informed decision.
Posted on Jun 16, 2009
3 Suggested Answers
  • 103 Answers
SOURCE: blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
Posted on May 07, 2008
abhi_patil
  • 569 Answers
SOURCE: canon i850 seems to be printing, but get only blank page
try cleaning the nossle of the cartridge , if that too doesnt work try cleaning the contacts of the cartridge holder, if that too doesnt work then take the printer to service center
Posted on Dec 19, 2008
Printing blank pages
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 11, 2013 | Canon PIXMA Pro9000 InkJet Photo Printer
Blank pages
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 25, 2012 | Canon PIXMA iP1000
Printing, but not full words Canon i850
Sounds more like the actual print head has become dried out and simply needs to be cleaned. This is a common problem with Canon Bubble and Ink Jet printers.
You should be able to remove the cartridge and then the print head shuttle that moves across the page. Once you have it removed, you will need to get a couple of Q-tip swabs and some DENATURED ALCOHOL, NOT RUBBING ALCOHOL as the water in rubbing alcohol will damage the printer head. Wipe the face of the printer head GENTLY with a moistened swab, you should see the dried ink dissolve, do this a few times until you see no further ink on the swabs.
Allow it to dry for a few minutes and then reinstall it into the printer. You will need to run the alignment function of the printer to ensure that the print is aligned properly. That should do it.
Cheers,
Keith
Sep 19, 2009 | Canon i850 InkJet Photo Printer
I have problems aligning printer heads on my Canon i850. I have clean the printer heads, replaced cartdridges, re-aligned them, but I still get lines through the printed material (phots mostly). No...
Please try to uninstall and reinstall your printer.
Clean your printer heads.
Perform a hard reset to your printer.
Print a test page.
Try using a different bond paper.
Make sure you are using original canon cartridge
If still you get an error. Replace your printer heads.
Aug 30, 2009 | Canon i850 InkJet Photo Printer
Colour printing comes out in lines across the whole page
Is the nozzle is perfect? i dont think so. But, if you print with best/photo mode is ok.
Jun 01, 2009 | Canon i850 InkJet Photo Printer
Canon i850 seems to be printing, but get only blank page
Dec 19, 2008 | Canon i850 InkJet Photo Printer
Blank pages coming out of i850 with new printhead
(1): Correct
May 07, 2008 | Canon i850 InkJet Photo Printer
Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Feb 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Prints blank pages only
Try brand new genuine cartridges, if that does not work, it is your printer's print heads. Canon has these built into the printer as opposed to having them built into each new cartridge. Sometimes cleaning the heads a few times does not do much at all. On some occassions I have cleaned the print heads over 20 times and have succeeded eventually in getting it to print. Good luck.
Sep 06, 2007 | Canon BubbleJet i560 InkJet Printer
Canon i850 InkJet Photo Printer Logo
598 people viewed this question
old marine
old marine
