Question about Jet Saws
Son removed the overload switch from the motor
Where can I buy this switch or do I have to replace the motor?
    Sergeant:
  • 384 Answers
I assume the switch is separate from the motor. In either case a new swich could be added. A replacement switch can be purchased at any hardware or home improvement store (ACE, True Value, Lowes, Home Depot). The black wire from the plug goes to one terminal of the switch, another black wire goes from the switch 2nd terminal to the motor.
Posted on Jun 16, 2009
My blind son overloaded the washer and it will not spin after I removed the clothes. The washer makes a noise like the motor is working but not connecting. how do I fix it?
The washer may have a broken drive coupling. This is a plastic coupling with a rubber insert mounted between the motor and transmission. If the coupling breaks, the motor will operate and make noise but the basket will not turn. You must access the motor to make this repair. The part is inexpensive but labor more costly. I've seen this many times while I was working on Kenmore washers. It is a lot better than broken transmission, and worthwhile repair. Overloading and wear and tear over time will cause these to fail.
Dec 27, 2017 | Kenmore Washing Machines
Electric motor overload protection device
It is easier to repair namebrand equipment than off the wall ones. I would open up the motor and take the numbers off the existing overload, get the equipment model, serial number, and then I can shop for replacement parts.
There are alternatives to OL protection.
Nov 01, 2017 | HP Air Tools & Compressors
We have a 100 ton press electric motor an a hydraulic pump.You have to hold in on the reset to make motor run.
The overload switch may have failed. Does the motor stop if you let go of the reset? If the motor (single phase) has a capacitor start, the capacitor may have failed partially which will cause overload because the motor just sits and hums without turning. If this is a three-phase motor, the overload button should shut off the motor starter which directly removes power to the motor. Don't jury-rig a switch to bypass the problem. Hope this helps!
Dec 22, 2010 | Garden
Lift motor overload
" Turn the power switch off, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
The lower board software contains a protective current measurement, should the limit exceed, it will give the ’lift motor overload’ -error. Try calibrating the lift motor and if not successful. Unplug unit remove motor shroud locate the lift motor. The lift motor driven nut is never supposed to reach either of the ends of the lift motor screw. Should this happen, the nut is likely to get jammed. Check that the nut is not against the motor frame nor against the stopper in the end of the motor screw. In a case like this the lift motor needs to be removed and the nut released by hand.
May 15, 2010 | Tunturi T60F T60F Series Treadmill
Washer will agitate, but not spin
there is a coupling that is behind the motor that brakes if the washer is overloaded,part number 285753A,it' around 25 bucks,it's a pretty easy job,two clips hold the pump on,remove them and pull off the pump,take out the two screws holding the motor clips on and remove them,pull off the motor and you'll see the coupling
Mar 14, 2010 | Kenmore 63942 Dryer
Hotpoint dryer nvl333eyoww, Motor runs, heating
Did you ohm out the thermal overload?
May 18, 2009 | Hotpoint Dryers
Magic chef compact fridgerator model mcbr445b1
you may just have a bad relay. with the power removed ..(unpluged)
remove the relay cover ( on the side of the compressor)
remove overload and relay
check relay for 4-5 ohms
check overload (if open it is bad)
let me know
Dec 21, 2008 | Refrigerators
LG 1285
Lg washers used to carry a 3 year warranty.check warranty as requires a new stator.
Jan 05, 2007 | LG WD-1280FHD Front Load Washer
Saws Logo
308 people viewed this question
Top Jet Saws Experts
Marvin
Marvin
woodzowl307
ray gallant
Are you a Jet Saw Expert? Answer questions, earn points and help others
