Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Door on my integrated Bosch fridge keeps opening
Fridge door on my integrated Bosch KIV3235GB01 keeps opening by itself. The seal (a proper Bosch one) was replaced a year ago so I don't know what's wrong. I've taken off the heavy oak door cover which partially helps but It seems the suction is just no good. Help!
  • 32 Answers
Seals rarely fail most likely needs hinges replaced,parts quite cheap
Posted on Sep 05, 2009
Integrated fridge door keeps springing open. what is causing this?
the magnetic seal along the door may have gone bad. or bad worn out door seals not keeping or creating the pressure needed to cling door shut
Feb 19, 2015 | Whirlpool Refrigerators
My Neff fridge (K4316X1/GB) door does not close tightly on it's own and so does not seal properly unless I press it home
Try the following:
  1. Make sure there is nothing sticking out the fridge what could keep the door from shutting;
  2. Take a good look at the hinges and perhaps clean them or lubricate them (using Teflon spray);
  3. There is a white rubber strip all around containing the magnet with which the door should seal itself. Clean this rubber strip and the surface of the fridge it lands on;
  4. Make sure the fridge is level.
May 31, 2014 | Neff K4664 Top Freezer Refrigerator
Drain clogged on MCBR415S
Unless that fridge has an automatic defrosting cycle, NO water should be collecting at the drain area under normal circumstances. The only time that drain is needed is during defrosting (manual or auto).
Does the unit ever turn the cool cycle off or is the fridge always running (does the fridge ever stop humming)? If the fridge is always running, ice will build up in the fridge and it is either because the thermostat is broken or the door is not sealing properly allowing the cold air to escape. This can be due to something inside the fridge is preventing the door from closing properly, the door itself being not properly aligned with the fridge compartment, a broken door seal or a bend door or a bend fridge frame.
Ice can build up fast when a fridge is installed in an area with high humidity (like in Florida) and the door is opened frequently (like every 5 minutes to get a beer out, like during a house party).
If the fridge door seems to seal properly and the fridge seems to keep things cool, it might be enough to defrost the fridge to get it back in proper operating condition.
When loading the fridge, allow enough space between items, to permit the air to circulate.
Good luck :)
Jan 06, 2014 | Magic Chef Refrigerators
Suction of freezer door
No, that perceived suction effect is the magnetic door seals 'grabbing" onto the fridge cabinet and pulling the door(s) shut firmly and securely.
Typically as the fridge gets older, you'll need to clean off both the fridge cabinet edges and the door seals to maintain a proper seal, which is essential to keeping the fridge operating properly.
Hopefully you find this Very Helpful and best regards!
Sep 23, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 | Freezers
Fridge door pops back open
The seal on your door may not be sealing properly, when you close the door the seal helps create a vacuum which keeps your door closed firmly, you might need to replace the door seal, you could also try leveling your fridge by putting shimmys underneath the feet, you might also want to check to make sure there is nothing sticking out of your fridge such as drawers or food racks that may keep the door from closing all the way. good luck.
Mar 16, 2009 | Refrigerators
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
814 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
