Question about Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood
On demand water heater won't stay lit
Replaced the thermocoupler, the issue seemed to improve, now the pilot needs to be relit up to 4x a day.
My tankless water heater is 4 years old. The pilot light will ignite the gas. However the fire goes out almost imediately and tries to re-ignite. Seams to have been gradullay getting worse.
Posted on Sep 03, 2009
    Problem Solver:
  • 6 Answers
It's the gas valve. This pretty common. The thermocouple produces a small amount of current from the heat and this current holds the safety valve open inside the gas valve. Sometimes the safety valve gets sticky and your symptoms describe it exactly. People are always frustrated by the time it is certain to be the valve. You need to replace the valve. No one is allowed to fix a gas valve - liability - gas etc. Replace the gas valve and your problem will be solved. I am a master plumber/gasfitter and I am confident that this will solve the problem. Been there - done that.
Posted on Jun 17, 2009
Why does my pilot light on my hot water take not stay lite
It depends on many factors, including brand, type of heater, age, gas pressure, maintenance, venting, proper installation of thermocouple, bad thermocouple, air intake cleaning, if the flame is clear blue etc.
Copy following link to read more:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 20, 2012 | Water Heaters
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Richmond power vent will not stay lit, the bunrer will lit than after about 5-10 min. it goes and tries to relite and than goes into lock down. after it about 5 min. you can reset it and it will do the...
Richmond-Ruud-Rheem
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
It sounds like you've read the manual.
And cleaned the burner parts according to manual.
You replaced thermal reset, but system is still tripping, so either the gas valve and tubing are bad, the thermocouple is bad, or there is a problem with gas pressure, or gas line.
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Apr 08, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a Rheem 50 gal. natural gas water heater mod#21V50-6A followed all instruction and can't get pilot light to stay lit.
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
Feb 23, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light will not stay lit
your thermocouple needs to be replaced. they are available at any hardware store.
Sep 16, 2009 | Water Heaters
My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Aug 10, 2009 | Water Heaters
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Pilot light won't stay lit after release of gas valve.tried few t
Most likely it's time to replace the thermocouple, the safety device that makes sure the pilot is lit. New thermocouples are cheap and you can find them at most hardware stores and the big-box places (Home Depot, etc.)
Here is a site with basic information to get you going.
Apr 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Whirlpool water heater pilot light does not stay lite
I have a Lowe's Whirlpool water heater. I've experienced the same problems as I've seen described here. My pilot light started going out several times a day. It was not such a big deal, the tank is well insulated so the water would stay warm - I'd just re-light the pilot before going to bed and before going to work. That worked well for about three days, but the problem got progressively worse until it just would not light at all. I replaced the thermocouple with a Honeywell universal thermocouple that I got at Home Depot - that did not solve the problem. I'm very handy, so I decided instead of going through warranty service and having to wait three or four days for replacement parts, I'd buy a new gas valve at Lowes and try that. It cost $54.00 and it worked. By the way, I put the original thermocouple back in and the pilot light stays lit - it was definitely the gas valve and not the thermocouple in my case. It was a real pain to do since I had to drain the tank, but it only took about three hours total. From what I've read, these things last anywhere between six months and two years. That's ridiculous, but at least I have hot water now. If you are reading this because you are considering purchasing a Lowes hot water heater, DON'T!!! I started my search for a replacement gas valve at Home Depot, but they don't stock them. Lowes had 8 on the shelf. That tells you something right there - the water heaters Home Depot stocks don't need to have the gas valves replaced before the tank wears out - there's no demand for the valves so Home Depot doesn't stock them. Lowes probably sells 8 of them a week - all the boxes were shiny and new, not dirty and dusty like some items get when they sit around in home improvement stores.
Nov 11, 2008 | Water Heaters
Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood Logo
805 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
