Question about Arrow T50P ARROW STAPLE GUN
How to remove jammed staples in staple gun?
I have an Arrow T50 staple gun that I put some staples in. The staples are visible in the side window, but will not come out when I squueze the handle. I also cannot remove them the way they were inserted. Any suggestions?
Patti from Illinois
  • John Zelinski
    John Zelinski Jan 16, 2016
    grandmafixit's got it right. Worked like a charm. Thanks
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Posted on Jan 07, 2011
  • 5 more comments
  • girlcanfixit Jan 24, 2011
    I meant to hit YES, but my curser was off a bit and I accidently selected the no... I was ready to throw away my T50 Arrow Fastener, but you saved me. The needle nose plier thing was not helpful. They would not go back far enough.
  • jolayos Apr 21, 2011
    Taking out small bolt, clearing jam, oiling, worked perfectly!!
  • grillo_john
    grillo_john Jan 07, 2013
    Was doing a fixit project on a late Sunday night and was about to go to Lowes and buy a new gun but this got me through the project. It took longer because my very, very old T-50M Gun kept jamming but I was able to get through it; Thank you very much.
  • Joan Sharkey
    Joan Sharkey Dec 01, 2013
    Geez! THANKS, mine is ancient but I finally cleared it.
  • Clj810
    Clj810 May 04, 2014
    i have removed the pusher rod, but i think something is still jammed inside that i can't see. Any more suggestions?
  • Jeff Wong
    Jeff Wong Sep 26, 2014
    Don't be afraid to disassemble by removing this screw and nut. It will give you access to anything jammed in there. Works like a charm.
  • Paul Rybarczyk
    Paul Rybarczyk Jan 27, 2016
    Would have worked fine for me but apparently the 2015 staples for my 1966 gun don't fit quite as well (yes, they are the correct size) and keep getting jammed.
  • 240 Answers
Pinch the clip located on the end of the Magazine Unit Pull out the Magazine Unit Remove jammed staples from the channel. You may need to use long-nosed pliers . Make certain that you are using correct size staples. Close Magazine Unit.
Posted on Jun 16, 2009
Craftsman 68514
The replacement pack for this gun say the staples are compatible with "Craftsman 68514 and 68517; Arrow Brand T50 Staplers T50 and T55; and Stanley/Bostitch TR110 and BT110 staple guns", so I assume they are also backwards compatible. That's just an assumption though.
Mar 22, 2013 | Arrow Tools & Hardware - Others
T50 elite wont staple
I just bought a T50 elite, and it will NOT staple too.
Simple 3/8" staples loaded and nothing comes out.
Jan 31, 2012 | Arrow T50P ARROW STAPLE GUN
Just got an ET50red electric staple gun. Loaded Arrow T50 14 mm staples with the points facing up and out of the tool. When I pull the trigger, the led worklight comes on, I hear and feel the stapler...
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Jul 31, 2011 | Arrow T50P ARROW STAPLE GUN
The info on the gun says it will shoot many different staples, but it will only take 3/8 staples and I need to use 1/2 staples to do the job.
The T50P stapler uses T50 staples of various lengths, including 3/8, 7/16, and 1/2. Is it possible that the 1/2 inch staples you are trying to use are not T50? All T50 staples are the same width and should fit your stapler. There are several other widths of staples that are not T50, although T50 is the most common.
Nov 29, 2010 | Arrow T50P ARROW STAPLE GUN
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
My T50M Staple strips break up in the gun and jam after 4-5 staples. This happens with old staples (10+ years) and with new staples that were purchased two days ago. Out of frustration I purchased a new...
The staples are held together with an epoxy. I have used staples that are older than 10 years. The problem is the gun. Check for dirt or a burk in the magazine as well as a bent pusher blade. My gun also had a problem loosing a screw and nut that attached at the blade guide.
Jun 12, 2009 | Arrow T50P ARROW STAPLE GUN
The door at the back of the staple gun won't close
You have too many staples in the gun. Chances are it was not shooting staples so you put more in. (Only holds 1 strip as if new from box) Check for a jam. Sometimes this keeps more staples from advancing. Please rate
Jun 05, 2009 | Arrow Fastener Co. Hd Staple Gun - T50
My arrow fastener model t-50m is jammed how do I remove the few
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Feb 14, 2009 | Arrow Fastener 509 9/16" T50 Staples
Arrow T-50 stapler
Take out the screw/nut combo @ the end of the gun where you load the staples. The whole rail that holds the staples will then come out and you can then get the little devils of the nested, jammed, rousted up staples out by sliding them out with a screwdriver. Don't jam the screwdriver into your fingers/hand when doing it.
Nov 03, 2008 | Arrow T25 Staple Gun
Arrow T50P ARROW STAPLE GUN Logo
15,164 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Marvin
Marvin
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
