Question about NEC VT670 Multimedia Projector
Nec vt670 projector , displays "the lamp has reached the end of its usable life.please replace the lamp" the lamp and filter are fine how do i over ride this error
  • 31 Answers
Typically you will need to replace the lamp. Do not try and squeeze the last hour from the lamp as there is now a chance if the lamp will shatter and scratch the mirror and lcd block rendering your projector with a permanent scratch when projected. If you already have a new lamp fittted then simply go to the menu setting, under installation or setup by memory and there is a reset option. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Posted on Sep 09, 2009
4 Suggested Answers
Gigatech
  • 259 Answers
SOURCE: NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
SOURCE: how to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
i believe you hit the up and down arrow and the enter button on the projector itself and hold hem in for few seconds and it will display lamp usage.
Posted on Jan 04, 2008
dhiman
  • 115 Answers
SOURCE: NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Posted on Feb 07, 2008
Message on screen-The bulb has reached the end of its usable life....and it has 97 hrs left and can't clear the message.
select Menu>>>[default]>>>[Clear Lamp Hour Meter]. do this after replacing the lamp.
below is a link to the manual. what you seek is on pgs E-30,31. Good Luck!
http://www.support.nec-display.com/dl_service/data/manual/english/vt660k_e.pdf
Sep 13, 2011 | NEC VT460 Multimedia Projector
The projector came on for about 10 minutes and then shut off
Welcome to FixYa.
The projector could be overheating or the lamp has reached its end of life.
Solution:
1. Clean or replace the air filter. 2. Check the lamp run time. If the lamp time has reached its end of life, replace the lamp.
Use the manual to do the above steps. Keep me posted.
Jas247
Aug 03, 2011 | Radio Shack Cinego D-1000 Multimedia...
How to clean filter for overhead projector?
use a vacuum cleaner to **** the dust out of the filter unit on the right side rear end of the projector (right side up directions).
Then reset the filter timer.
MENU, DEFAULT, CLEAR FILTER USEAGE
Apr 19, 2011 | NEC VT670 Multimedia Projector
I can't figure out how to replace my projector lamp for an NEC VC 670 projector. A little help please?
You need to use a phillips screwdriver to first snap off the cover on the bottom and then undo the 2 screws holding it in. The manual is here ( page 53 ): http://www.projectorcentral.com/pdf/projector_manual_2522.pdf
Feb 28, 2011 | NEC VT670 Multimedia Projector
NEC VT670 - Lamp won't light. Replaced with new lamp, but gives same error. The manual says to wait a minute and then turn on the power again, but this does not work.
I have the same problem. The lamp appears OK. but she isn't coming on. It seems like a problem to start the lamp.
Did you find a solution?
Jan 22, 2011 | NEC VT670 Multimedia Projector
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
My NEC VT660K wont power up.
Hello.
Some suggestions from NEC support:
Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on.
• Ensure that the lamp cover or lamp housing is installed correctly.
• Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you’re presenting is particularly warm, move the projector to a cooler location.
Hope this helps.
Nov 05, 2009 | NEC VT660K Multimedia Projector
Feb 27, 2008 | NEC VT47 Multimedia Projector
Status indicator / no lamp
The power supply unit ballast is bad for the vt670 part # 3n100572
Feb 12, 2008 | NEC VT670 Multimedia Projector
Whatever button i press the status light flashes and nothing happens?
hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Apr 20, 2006 | NEC VT460 Multimedia Projector
NEC VT670 Multimedia Projector Logo
370 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
