Question about IBM Infoprint 6500 Matrix Printer
IBM 6500, printer won t put paper on first line.
First line motor shaft broken.
We need the motor IBM P/N, please!
Thanks!
    Scholar:
  • 111 Answers
I can supply you with the motor if needed. Please contact me @ 708-597-4222
Rory
Posted on Jun 18, 2009
Hp 4L printer won't pickup paper from tray. Sequence- green led light- motor running but with grinding- no movement from pickup roller or foot- finally a misfeed led light.
That is a very common problem with the Laserjet 4L and 4P printers. The sound you hear is caused by a broken motor drive gear. This is a small plastic gear on the drive motor shaft. They can develop a small crack which prevents the motor from turning the gears for paper pickup and toner movement. When the motor tries to turn the broken gear can not turn the other gears and makes the popping or grinding sound when the gear teeth slip. You will need to replace the motor gear, it is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
I hope this helps,
BuddyMc
Jul 16, 2012 | HP Office Equipment & Supplies
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Printing problems (InfoPrint 6500/iseries)
need more info plesae give me the most information on type of equipment and software issues and driver setting if you know and version of software may be helpful infor mation
contact threw this web site
rod the candymangandy
Feb 03, 2009 | IBM Infoprint 6500 Matrix Printer
IBM 1352
DC Pick motor error: No Encoder feedback. Try to remove all paper from tray 1 and replace it.
It basically means there is a tray1 paper feed problem.
Oct 14, 2008 | IBM Infoprint 1352 Laser Printer
Bar code
try changing the chacters per line, print out a config page and towards the bottom of this it will state the current settings
Jul 15, 2008 | IBM Infoprint 6500 Matrix Printer
Broken belt, motor wont turn
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=721048
Generic problem for all Vacuums
Broken belt, motor won’t turn
Posted by msmclovin on Jun 29, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the motor shaft won’t turn then you may have a bad motor or a stick carbon brush, but if it is just the belt the replace the belt with a genuine belt because the average belt change id every 4 to 6 months for the best cleaning and to store the extra belts in a Ziploc bag in the refrigerator. But you question does not tell me what brand name and model # it is so I have a hard time to diagnose the problem for you so my explanation if just a generic one and should work for you but next time please note the brand name and model #. If you have further problems please feel free to contact your local vacuum cleaner dealer in your area or call the Kirby cust serv dept listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 29, 2008 | Vacuums
No Paper Error
You could have two problems. One the paper sensor in the cassette could be jammed or broken, The clicking could be the sensor jammed next to the feed roller. If not it could be the fuser gear is broken.
Jun 17, 2008 | Brother MFC-8860DN Printer
To add paper size in IBM infoprint 6500
Start,
Settings,
Printers or ..,
Files,
Server Preporties
and a create new form
matrix or inc
Dec 19, 2007 | IBM Infoprint 6500 Matrix Printer
PRINTING ON A BLACK BACK PAPER
DYE YOUR RIBBON WHITE SPORT!
White ink the ribbon, should do the job, never seen anything comercially for it.
Nov 19, 2007 | IBM Infoprint 6500 Matrix Printer
Black back media
Hi Daniel,
This occurs because of the light sensor perper out sensor. A quick fix is locate the sensor on the left hand side of the paper path and then temporarily tape a piece of white paper over it. You just need to make sure that you keep an eye on the printer as it will not report paper out, now.
Aido
IBM Infoprint 6500 Matrix Printer Logo
143 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
