Question about InFocus Proxima UltraLight LS2 Multimedia Projector
No power to the projector
I normally leave my projector turned off with the power cable plugged on the unit. one day, the light LED has disapeared. I wanted to switch it on, no joy. what should I do? What may have gone wrong?
  • 2,237 Answers
The power supply is bad and needs to be replaced. unfortunately, infocus no longer makes them. sorry.
Posted on Dec 29, 2009
The lamp led light comes on each day on the second time I use the projector. It will not then play anything. I 'm guessing the light is not gone as it always works first thing in the morning but never at...
I think the power supply in the projector is faulty, you should bring it to repair centers for checkup, the power supply might not be receiving that much voltage.
Mar 07, 2014 | Optoma EP721 Projector
Christie ds+6k, buttons getting power, LED display has no power, and will not powering on
Button Panel lights up with power cable in ,means the power supply is ok
pls check the mainboard
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Jan 11, 2014 | Christie DS 6K OEM Projector Lamp
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here:
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
TDP-S8 Power supply led not lighting up. Unit not working
There seems to be problem in your power supply. Look for any swollen capacitor --- generally 3300uf, 10V. Be careful about the polarity of the capacitor before you take it out. Check the capacitor to make sure how it's mounted ( for polarity purpose). Negative side of capacitor will be toward the outside of pc board. Substituting 2200uf, 16V capacitor for 3300uf, 10V will work ok.
Mar 15, 2009 | Toshiba TDP-S8 Multimedia Projector
Hy, having problem with to conect projektor to the computer Anybody can help
The projector should have a cable similar to the monitor cable that would normally be hooked into the computer. The cables work the same and the one coming from the projector will use the same port as the normal monitor cable. Make sure that there is a good connection on both ends -sometimes one or the other get moved and the connection is lost.
Once the cables are hooked up, the projector should be turned on. Normally the projector will soon begin a startup routine and will cause an image to be shown on the screen. You can focus the image during that time.
After the image goes away you should be able to display whatever you want from your computer's software.
Normal problems in doing this are: leaving the lens cap on the projector, having a burned out bulb - once the power is turned on for the projector, it should cause the bulb to come on. Some models have a power on switch and a display on switch that must both be pushed to make the bulb light up.
Hope this helps.
Dec 26, 2008 | ASK Proxima C160 Multimedia Projector
Infocus lp600 not working
MAke sure that cables are properly connected, it might be that it is not getting any signal from the source.
Hope this helps
Oct 28, 2008 | InFocus LP 600 Multimedia Projector
Projector not working
I have the same problem with a HT250, red power light on back of projector will not come on. But if you leave the projector plugged in and power switch on it will light after some time and the projector works as normal. Any suggestion please email
Apr 22, 2008 | SIM2 Televison & Video
My toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Jan 24, 2008 | Toshiba Satellite A135-S2276 Notebook
Infocus LP725 projector
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
May 25, 2007 | InFocus LP725 and LP735 Replacement...
InFocus Proxima UltraLight LS2 Multimedia Projector Logo
107 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
