Question about Mitsubishi VS-60805 60" Rear Projection Television
Mitsubishi VS60805 screen
Looking for replacement screen for Mit VS 60805. Original one damaged in move.
If I can't get my 60805 working properly again I may soon have one :-)
I'm located in Orange County, CA, so if you're close I may be able to help you out.
Posted on Sep 26, 2009
Mitsubishi VS-60805
What you probably see is a burning area due to Cooling Fluid leaking from one of the CRTs. If this is the case, It is not worth fixing in my opinion because the Board would have to be replaced and the leaking CRT would also have to be replaced. The availability of the Board is doubtful Due to it's age. You can check at 1800-553-7278. This is Mitsubishi's parts department #.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
I have a VS 60805 and i need a Convergence Generator. They say these are no longer Available. Any Suggestions?
General Consensus is that Mitsubishi is a Piece of ****, has been for a long time and I was lucky that my Set worked as long as it did. I guess it is just another benefit of not have any national product in the US anymore. No matter I will never Buy Mitsubishi Again.
Jun 25, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Where can I get good E2PROM settings for Mitsubishi VS-60805?
I have this model and just got it working again. I have a Service manual also. But unsure about checking my settings
Jan 30, 2009 | Mitsubishi VS-60805 60" Rear Projection...
No picture but sound
I had the same problem with the same model. If you pull the cover off the speakers in the front , then the small black panel. looking from the front past your lamps are the 3 main boards, the r/h board has wire jumpers connecting to the center board. The set that is closest to you had a bad/loose/corroded connection on mine. All I did was resecure connection(try moving them with your fingertip) and turn TV on and check.
Jan 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805
Which transformer do you need. i have a source for alot of mitsubishi parts.
Mar 20, 2008 | Televison & Video
Picture turns red and blue color after television has warmed up
sounds like u are losing green? is that right. could be loose connections somewhere because it works at start up then fails when it heats up. Look in the yellow pages for a mitz auth servicer or call mitsubishi for one near u.
Dec 13, 2007 | Mitsubishi VS-60805 60" Rear Projection...
1992 mitsubishi
try vancebaldwin.com or MCMelectronics
Dec 09, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Cleaning lenses/lamps on mitsubishi VS-60805
A can of compressed air might do the trick. If dirt is stuch, I'd suggest useing the same chemicals/cloths/etc you would use for cleaning camera lenses. Check at your local photo store.
Just make sure the lenses aren't hot when you apply cold and/or flamable chemicals.
Nov 04, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
141 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
