Question about Samsung Pn51e7000 51 Inch 1080p 3d Wifi Plasma Hdtv
When I turn on my Samsung PN51E7000, it works fine for about 5 minutes then turns off and immediately comes back on. Sometimes it's only once, but frequently it's 2-4 times in succession before it stabilizes and stays on. We have HAD A DVD player attached since we bought the TV 11 months ago and just added AppleTV through the HDMI-DVI plug. Any idea as to the cause of the turn-off/turn-on problem?
    Top Expert:
  • Samsung Master
  • 51,898 Answers
Failing power supply
Posted on Jul 14, 2017
SOURCE:
djnick989
  • 1067 Answers
SOURCE: fan check issue
ya need to get fan fixed is safe mode cuse they genrate alot of heat have to have it in well vented area on a nice power strip like monster
Posted on Jan 09, 2008
MikeMaierTV
  • 206 Answers
SOURCE: Samsung DLP TV HL-R5667W shuts off intermittently
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Posted on Feb 13, 2008
lukster
  • 217 Answers
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Posted on Aug 03, 2008
  • 93 Answers
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Posted on Nov 06, 2008
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
My Samsung DLP Tv turns off after about 3 minutes. What needs to be replaced?
i think it could be trip switch in the back of tv it should be a little blue button you can try put a bit of tape over the button it might work and if its that you can order a new one i put tape on mine and its still working
Feb 21, 2016 | Samsung HLS5086WX/XAA
CS-40503 takes about 10 minutes for the picture to appear once the set is turned on (sound comes on immediately)....when the picture does appear, it's dim for approx. 5 seconds then comes up to full...
IF THIS SET HAS PIP (PICTURE IN PICTURE) THAN I'D SAY THE PIP MODULE IS GOING BAD. YOU CAN REPLACE IT OR GET THE BYPASS PLUG FOR IT. IT JUST PLUGS IN.
Dec 10, 2009 | Mitsubishi CS-40503 TV
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
My samsung projection television model pch521r wont stay on
when the set does come on do you notice any thing odd in the picture or sound of the set.
Aug 19, 2007 | Samsung PCH521R 52" Rear Projection...
Tv wont stay on
Check for CRT coolant leak on PCB.Clean spill, try again to verify.
Samsung CS72D4V
The problem here is moist likly the regulator circuit or the power supply has a defective component in that circuit. This is a solid state set and should not be services by un quailified service perso. Good Luckns
Jun 23, 2006 | Samsung TX-R2735 27" TV
Open Questions:
See all Samsung Pn51e7000 51 Inch 1080p 3d Wifi Plasma Questions
Samsung Pn51e7000 51 Inch 1080p 3d Wifi Plasma Hdtv Logo
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
