Question about Boating
Motor looses power under load 1989 90 hp mariner pro series
The motor will perform perfectly for a period of time, then without notice it will bog down and loose power under a load. the motor idels fine and reves fine but again you engage the drive and the motor barley has enough power to pull itself.
have replaced spark plugs, and the motor recently had the carbs cleaned, lower unit serviced, etc. recently
i am thinking it is fuel related, either a fuel filter that needs replaced, a primer bulb that is bad or the gas line connection to the motor is faulty
does nayone have any ideas or suggestions?
  • thomas foster
    thomas foster May 11, 2010
    have you done a compression test when the motor is hot?
    Champion:
  • 207 Answers
If coppresion is fine then you have a electrical problem more than likley your power pack cdi is gettin hot and breaking down
Posted on Jun 27, 2009
Yamaha EF2800i. Voltage drop under load. Runs very smooth with no load.
Sounds like a governor issue. Check linkage to governor.
Oct 23, 2017 | Yamaha EF2800i Generator
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Why does my mercury outboard idle perfectly but stall out under load?
Your carbs are probably dirty. Remove the carbs and clean out all jets and passages with carbcleaner and compressed air.
Nov 13, 2014 | Clymer Mercury/Mariner 75-275 Hp...
1992 60 hp motor bogs under full power????
try priming the fuel bulb when it boggs down and if it speeds up then replace fuel pump diaphrams etc and clean carbs and balance to start a fresh ! fuel tank clean ?
Jul 24, 2014 | Seloc Johnson Evinrude Outboards 65-300HP...
Motor Guide pro series 46lb thrust 12 volt trolling motor, no power to motor
check the plug itself that goes to motor open plug see if wires are broke
Mar 02, 2013 | Boating
Idles but bogs down with a load
How about a defective fuel pressure regulator, buy a fuel pressure test gauage from Autozone and test the fuel pressure under a load and at idle..
Sep 17, 2012 | 1988 Dodge D-Series Pickups
Is it compatible 3.5 HP engine with the boat? (mariner 4) if yes , when i used %30 of power just alone back side go down and can not control properly . engine is TOHATSU M 3.5 S
Your motor is too large.
For the Intex Mariner 4 Intex recommend an absolute maximum of 3HP (2,2kW) and the motor must not weigh more than 40lb (18,2kg).
Those limits assume that you are using the Intex motor mount kit (Part No. 10658) and that the boat is correctly loaded and inflated.
In reality and from experience I would personally recommend 2HP maximum power and to keep the motor as lightweight as possible. Although the Intex Mariner 4 can take a motor mount, it's really a rowboat and is not suited to using a motor for extended periods, but just as a convenient tender to a larger boat it's fine.
Dec 15, 2009 | Intex Mariner 4 Boat Set
Kawasaki 21 hp motor periodically misfires
SOUNDS LIKE THE COIL IS BFAKING DOWN
Oct 30, 2009 | Garden
Boating Logo
342 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
