Question about Mitsubishi HC900 Multimedia Projector
Need a part number for the color wheel. thank you model # HC900
  • 1,555 Answers
Here is the complete list of components part No used in your projector download and save it for your future use it's in pdf format
www.panasonic.com/business/provideo/support/includes/pdf/parts-services/exploded-view/AK-HC900.pdf
Posted on Jun 16, 2009
I have the m50wh72s rca dlp....and will be changing my bulb with thanks to this site!.....but what about the colorwheel?...is it easy to change ?....and is it exspensive to buy?
The color wheel if used may no longer be available from RCA. With the exact model number GOOGLE the model number with the words COLOR WHEEL after it and if I remember some of the wheels were rather expensive.
Let me know if you have questions.
Regards, SD TECH
Sep 17, 2011 | RCA Televison & Video
It not bringing out color.it showing black and white
HI,
I will need some clarification as to the model number of your projector to best help you but in general if you have a DLP type projector & suddenly lose all color to your image then the color wheel has failed by burning out or breaking. The color wheel sits directly in front of the projection lamp & if you take your lamp out you can use a flashlight & point it in towards the spot where the light comes out of the lamp & look at the color wheel. The color wheel has 4 to 6 different color pieces called segments like yellow, red, blue & a clear segment. You will be able to see if the color wheel is broken.
If it is you need to have the unit serviced. If you're handy you may be able to order a new color wheel. They are usually around $100. There can be other causes as well but the wheel is the first place to investigate. Please let me know if this was helpful.
Thanks & good luck,
Jim
Apr 14, 2011 | Acer Office Equipment & Supplies
Part number for color wheel
That model is a plasma TV? Plasma TV's don;t use color wheels. Only the DLP sets do.
Aug 15, 2009 | Samsung Televison & Video
Instructions on How to change an RCA Color Wheel
You can get help at;
http://servicemanuals.vstore.ca/
They will charge for manuals but they also give on-line tech support free!
Apr 06, 2009 | RCA HD61LPW165 61" Projection HDTV
Samsung dlp 6163w color wheel
Ours was on the color wheel. I also went to samsungparts.com and entered my tv model number and we could veiw the color wheel. However, the one we needed is back orders . I hope your is not.
Mar 02, 2009 | Samsung HL-P6163W 61" TV
RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
DV10 Color Wheel Replacement
Hello, the information is as follows:
Part no: 70.18r26g01
Cost: 129.00 + shipping
Model :Optoma DV-10
Contact no: (408) 383-3710
You may also contact the "out of warranty" repair department at 888.942.2929.
Glad to help.
Aug 18, 2008 | Optoma MovieTime DV10 Multimedia Projector
About the color wheel option
Hello Brandon B,
look on the side of the unit there will be a sticker with Model number, serial number and Version code. The version code will tell me what color wheel you need. There maybe some CCA adjustment you need to do using the remote in Service mode. Let me know what the version number. We will go from there. You can contact www.interactiverepair.com they will walk you through the installation process
Best regards
circuitcity
Jun 23, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Mitsubishi HC900 Multimedia Projector Logo
229 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
