Question about Cycling
How do you calculate the number to enter?
I know how to change the number in the Vetta Innovator C-100 cycle computer but I don't know how to calculate the number to enter. My tire size is 26'' by 1.9''.
  • Anonymous Mar 17, 2014
    The problem: "A piston cylinder device contains only saturated water vapor at 400 F. The piston is frictionless and sealed such that no mass crosses the boundary. the vapor is condensed at a constant temperature to saturated liquid." a)calculate the heat transfer and boundary work done during the process. b)if the cooling process then continues isobarically from point 2 until the liquid is further cooled to 100 F. Calculate the additional work done and additional heat transferred. ...point 2 being the saturated liquid state. I am having trouble finding an equation to use that does not incorporate volume or pressure. I need a guild into the right direction. Thank you.
Vetta uses circumference so yours would be 2055.
by the power of google:
http://www.vetta.com/Tech%20Support/DP/C-06.1_uk.pdf
hope this helps!
Posted on Jun 17, 2009
I lost the instruction manual to my Vetta C 5 cycle computer After changing battery lost all settings Where can i get manual
Simple Google search for "vetta c-5 manual" yields instructions for calibration in the first result:
Setting:
  1. Press the button to get to the "Odometer" mode (">>>" steady)
  2. Press and hold the button for 4 seconds to enter (m/hr)/(km/hr) setting mode.
  3. Press the button when the desired units are displayed. Calibration screen will appear.
  4. After 4 seconds the last digit will begin to flash and rotate change. Press the button when the desired digit is displayed.
  5. Repeat for remaining digits
As for what number to put in, refer to the chart on this page:
https://www.sheldonbrown.com/cyclecomp_f.html
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Oct 17, 2017 | Vetta Cycling
Bell console 200 bicycle light. Which setting is needed for a 27wheel?
Try this: http://www.livestrong.com/article/189600-bell-bike-computer-instructions/ Actually, the number entered is typically the circumference of the tire in millimeters. Check on of the videos at this link: calculate bike computer wheel number Google Search
May 11, 2017 | Bell Cycling
How do I program my bicycle computer? My battery died, I changed it and now need to reprogram. Can you help? Bicycle tire size is 700 x 23C.
Just get the manual and keep it for the next time you need it...
A simple web search for "Vetta RT288L manual" finds it.
Sep 14, 2011 | Vetta RT288L
How do I reset a V50 Vetta speedometer/odometer?
Get the manual...
http://www.vetta.com/support/manual.aspx?type=cycling computers
http://www.vetta.com/Tech%20Support/DP/v-50uk.pdf
Apr 17, 2011 | Vetta Cycling
Need instructions for 12 function cycle computer SW500NM
The number the computer gives you in the initial reset is a 4 digit number (the one mine gave me was 2124) with the last digit flashing. Since I had a 26" tire, I had no clue what I was supposed to enter. I eventually googled a page that gave me the answer. The actual size of my tire is 26x1.90. Go to: http://sheldonbrown.com/cyclecomputer-calibration.html#ccc
According to this page, our Schwinn 12 function computer falls in column "F" and the 4 digit number I would use to replace the 2124 number computer initially gave me (with the "4" flashing) would be 2055. This number represents my bikes actual tire size in the corresponding column. I had tried 2045, since it was the closest number the chart in the owner's book gave, but the speeds and distance computed didn't seem like it reflected much accuracy.
However, doing the math by comparison of 26x1.75 and 26x2 sizes, I find the 2055 number to be exactly the right number for my size tire (26x1.90) as listed in group F. I guess if you have a metric sewing measuring tape, you could measure the circumference of your tire and come close to the desired number, since that is what it is supposed to represent.
Since the manual that came with the computer can be confusing, I recommend going to that page if your tire size is not represented in the chart Schwinn provided with the computer. There is also a lot of useful information about bicycle tires in the other pages of the link I provided, too. Good luck.
Victor
Jun 07, 2009 | Pacific Cycle Baby Gear
How do you go about making the calibration setting for the bike/tire size on the vetta innovator c-100
Push the MODE button until ODO appear on the readout. Press and hold the SET key for two seconds and the calibration setting will appear. Press the SET key to advance to the desired digit, then press the MODE key to advance to the desired number.
May 10, 2009 | Cycling
Tire size for mitsubishi outlander
Here's a good tire calculator and it gives you the speedo changes etc.
Tire calculator
Mar 24, 2009 | 2006 Mitsubishi Outlander
Cycling Logo
575 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
