Question about Dell Inspiron 1521 Notebook
RAM TESTING HELP!
Hey guys I want to know if there are any ways to test your RAM and see if it could be causing problems. All I have done so far is opened up task manager and went to the performance...it shows about 850 as physical memory usage. My laptop has 2 gigs. shows that 1170 is cached? idk what that really means. any help plz!
  • bostianz Jun 16, 2009
    How do u know what type of RAM or laptop has
    President:
  • Dell Master
  • 1,996 Answers
See explanations of task manager performance fields here. If you want to reduce the amount of ram used by system resources, you'll have to disable some of the processes that are running at startup. To do that, see links here, here, here.
For your test ram tool, see here and here are instructions.
You don't mention what kind of problems, but I suggest for general safety you work through at least the first four steps of these malware removal protocols. Otherwise see here, here, and here for advanced reading and helpful forums.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 16, 2009
1996 ram 1500 no fire got fuel changed everything help
Is the fuel only the initial prime? If so, that isn't good enough. Use a gage and check proper fuel pressure, engine cranking. You said no spark. Engine cranking do you have fuel injector pulse?
If your missing all three, have to check cam and crank sensor signals.
I don't know what testing you have done? Any applicable trouble codes? As far as parts you replaced, if electrical, have to check wiring circuits and wire connector.
Check primary voltage at ignition coil, engine cranking, use a test lite to check for voltage, should be hot.
Jun 15, 2018 | Cars & Trucks
I have 2000 Chrysler town and country van that as your driving the engine will cut off. So far I have replaced the ignition wires, the spark plugs, the fuel filter and I have had fuel injection servic
You installed parts & asked for various services to be done
What you failed to do, was testing required to find your vehicle
problems
Most likely, unless your way behind or never do any Preventative
Maintenance, you didn't need all that was done,at least to fix the
cutting off issue
Have to check for OBD Codes,road test with scan tool,look
at data & component test, to find problems,not replace parts
in a wish & hope strategy
Sep 30, 2014 | 2000 Chrysler Town & Country
I have a 2000 chevy silverado z71 and it takes a
Having the lights go on, doesn't tell you the battery is good
The batteries age & usage & testing it, may tell you something
What your telling us, is an obvious strain on the battery,so it
won't last long, until you find the cause of the no start.
How about telling us about the testing that has been done so far
Fuel Pressure-that sounds like a possible cause for the slow
start after sitting
Failing Fuel Pump is a possible-test those items
How about doing a cylinder leak down test, to see if you have
valves that seal & can build compression
Do a cylinder contribution test or cranking test
Look at scan tool data,the answer may be there also
How about checking for codes
Enhanced as well as Generic
Sep 27, 2014 | Cars & Trucks
Just bought a 2003 Dodge Ram pickup 1500. Wont
How would an Emission Center know about reflashing anything ?
If you went to a private shop, that is licenced to do emissions & they
worked on it & found a bulletin on reflashing, to solve a problem,then
that is a possible
If no road testing with scan tool & no component testing was done,
then they don't know what their taking about & should keep their
opinions to themselves
You failed for a reason
What was that reason?
What Emission Gas failed?
That is what you have a shop work on
2007 hhr won't start
Check for spark at plugs. Check for fuel at intake.
May 23, 2014 | 2005 Chevrolet Equinox
Under-appreciating
There are a lot of things that impact the accuracy of a testing device like that, especially when it is in an uncontrolled environment. Start with the test subject:
1. What kind of beer?
2. How much did the subject eat while drinking?
3. What medical conditions does the subject have?
The testing machine"
1. How is it stored?
2. How old is it?
3. Exposed to anything harsh like high humidity? Temp?
4. What environment was it used in? Cold Hot?
The only real way to know is to test it against another testing instrument or use a known solution of alcohol and water
Apr 01, 2014 | Watchdog Breathalyzer Watchdog...
Poweredge 1950 won't start
this is common, if your place was cold its possible that something has died when turning on again, you could try and pull out ram in an order to see if one has failed, get the memtest download and make a boot disk to test the ram has not become faulty, test each stick alone, Hiren boot disk has all the good stuff for testing, its a free tecky tool for engineers.
Feb 13, 2013 | Dell POWEREDGE 1950 Server
I replaced the solenoid and now i dont have any power going through to anything! can you help
You need to start at the begining, and give details of the issues, and what was done in the way of testing so far.
Sep 13, 2010 | 1994 Ford Tempo
Will not boot. Turns off after 5 seconds
i would check your memory sticks i had the same problem and it was my ram.they get full and ware out
Jun 12, 2009 | HP Compaq nx9420 Notebook
Dell Inspiron 1521 Notebook Logo
75 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
