Question about JVC AV-27230 27" TV
Does the JVC AV27230 require a digital to analog converter?
I have the JVC AV-27230 TV. Does this unit have a digital or analog tuner. I always thought it had a digital tuner but now that I am not receiving any picture through my rooftop antenna I am not sure and I do not want to purchase a digital to analog converter box if not necessary. Is there a setting I need to deal with or do I need a converter box?
    Problem Solver:
  • 9 Answers
If you are going to continue using the rooftop antenna, then you will nee to purchase a digital converter box. Those television sets are only analog. You do have an option to get Directv or Dish network and you will not need a converter box at all. Directv and Dish network are 100% Digital and the receivers work as converter boxes for that product only.
Posted on Jun 16, 2009
NO CHANNELS
What specific model of JVC multi-system TV do you have? What is the signal source?
The majority of the JVC multi-system TVs that I've researched only have analog tuners (NTSC, PAL). The AV-29LX is an example of the older JVC TVs. Since most over-the-air signals are digital, you will need a digital-to-analog OTA signal converter to watch any signal from an aerial TV. If you have a cable system that has upgraded to digital cable, you will need a cable box.
Converter boxes are harder to find but there are a few remaining. Here's one for the US: http://www.amazon.com/Magnavox-DTV-Digital-Analog-Converter/dp/B0013ZKZGU .
I wish that I had better news for you.
(A few low-power stations still broadcast in the analog format. However, you have to be really close to the station or have an outdoor antenna to have a chance at receiving the signal.)
Mar 30, 2014 | JVC 29" Flat Screen Multisystem TV
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Im trying to hook my standard antenna up to my jvc av 56p585. i dont have manual. and i cant get any channels. what do i need to put my tv on to get my basic local channels
This JVC TV has an NTSC (analog) tuner. So it can only receive some of the few remaining low power tv stations that are still using analog transmitters. Depending on your location, you may not have any of these stations within the range of the antenna.
You need an digital-to-analog tuner to get additional channels. Use tvfool.com or antennaweb.org to check for stations in your area and the appropriate direction to point that antenna. (You may need an amplifier since digital stations are either sufficient signal for the tuner to use or you get "no signal".)
Please note that the d-t-a tuners that were available with the government coupon cards only handles standard definition signals (480i). The HD tuner digital to analog converters are available at some online sites but cost more.
I hope this helps.
(you can use a tuner in your computer (USB or PCI card), but you will need a converter unless your video card can put out a signal other than RGB. The HDMI port on the TV will not interface directly with a computer.)
Nov 06, 2010 | JVC Televison & Video
JVC AV27230 had a bright white screen with lines across it. now just went black
You may have a power supply issue and at the flyback transformer .
There also may be components in the circuit surrounding the fly-back that are malfunctioning.
The issue points to a repair at the board level. A tech will be able to determine this with test where the issue is on the main board.
I hope this helps.
Apr 25, 2010 | JVC AV-27230 27" TV
JVC av-35750 digital or analog???
Unfortunately this TV does not have a digital tuner built in.
Is not digital ready.
Jun 28, 2009 | JVC AV-35750 35" TV
Cable went out yesterday, when came back their was no picture or sound. green light flashing on timer. jvc av 27230 27" tv
did the input line still work, for the cable input do an auto search channel to reset your tuner, if it didn't work stop right there your tuner is mabye out
Feb 20, 2009 | JVC AV-27230 27" TV
Digital Tuner or Analog
I have the JVC AV-27020 and had to download the manual just today. I checked where I got my manual and they did not have anything for an ACV-27020. The link for the TV manual I downloaded is below. Maybe it will help.
http://www.retrevo.com/s/JVC-AV-27020-TVs-review-manual/id/279ag501/t/1-2/
Aug 10, 2008 | JVC AV-27020 TV
White lines at top of av27230
Your posted description is a known (common) problem for the JAV-27230 and should be easily repaired. The vertical capacitor (C424 - 100uf/35V) needs to be replaced. It is relatively cheap and can be bought from any electronics parts store.
in some instances, it could be the vertical IC starting to fail or even a simple case of cold solder.
As always, extreme care when repairing the insides of a TV unit since HV can still be present even when off and unplug. A little knowledge of electronic components and use of a soldering iron should do just fine. Should you not be comfortable doing a DIY, then perhaps you can ask the assistance of a buddy who has some soldering experience.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Feb 10, 2008 | JVC AV-27230 27" TV
Television
acording to spec sheet this unit is not equip with a digital tuner you will need a converter box before feb 9 2009
Jan 16, 2008 | Televison & Video
Universal code for JVC-AV 27230
www.remotes.com
please try this web site you will get the solution
good luck.
Oct 17, 2007 | JVC AV-27230 27" TV
JVC AV-27230 27" TV Logo
474 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
