Question about Nokia e65 Cellular Phone
How can i select the memory (nokia e65) as phone and not the memory card? i'm trying to increase font size of my nokia e65
    Problem Solver:
Use nokia pc suite to install the apps and there you can specify where you want to install it..
to change the memory selection for your msgs, you can go to menu>messages>options>settings>other>memory in use
there you can change this for your sms..
cheers..
Posted on Sep 21, 2009
Nokia E65(memory full close some application or try again)
Change your Nokia E65 Message Memory.
for that you should go to message & go to options select settings there you'll find other select it in that you'll get memory in use default phone memory is selected change it to Memory card your problem will get resolved.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 18, 2011 | Nokia e65 Cellular Phone
Change Font Size on Nokia E65
hi
The font size cannot be changed by using any option in mobile .bu you can use one trick to perform this. go to the following link and follow those instruction provided there.. this will fix your problem.. .
if it works kindly vote for the answer..
http://www.dreamstrikes.com/nokia/510-nokia-e65-fonts-too-small-get-new-fonts.html
thank you
Dec 22, 2010 | Nokia E63 Cell Phone
How to change nokia e65 font size
The font size cannot be changed by using any option in mobile but there is a trick to do it .
The following link helps in increasing font size
Jun 24, 2010 | Nokia E63 Cell Phone
I just have an e65 nokia cellphone but the phone is on offline mode.. how can i put it to online mode?
hi just select any other profile it will automatically deactivate offline mode
May 18, 2010 | Nokia e65 Cellular Phone
How to increase the font size of n73
You need to download font magnifier software from any mobiles software website. Then install this application in your phone memory and then your phone font size increases.Later on, you can uninstall this application and return to your original font.You have to install this software/application because there is no other way to increase font.
Dec 24, 2009 | Nokia N73 Cellular Phone
Tamil font problem in mobile phone nokia e65
Sorry Mr jamal you can't view tamil fonts on your e65 below is link to the tech issue given by the company which you can read.
http://www.allaboutsymbian.com/reviews/item/Nokia_E65.php
Jun 15, 2009 | Nokia e65 Cellular Phone
Nokia E65 mobile phone font size to small
Nokia e65 manufacturer created no room for font enhancement, but there is only one solution.
SOLUTION> BUY PSILOC FONT MAGNIFIER AT WWW.HANDAGO.COM STORE.
Jan 14, 2009 | Nokia e65 Cellular Phone
Nokia E65
Why don’t you use Font Magnifier?
http://www.e-series.org/archives/356
it really works
Oct 13, 2008 | Nokia e65 Cellular Phone
Small letters
If you wish to make letters larger on the E65 the only way to do this is to download a "font magnifier". I purchased a product for my E65 called "PSILOC FONT MAGNIFIER" it works well and you adjust the font size until you are satisfied with its appearance. If I recall correctly I believe you can try before you buy too. Hope this helps.
Grandad Fatboy
Mar 21, 2008 | Nokia e65 Cellular Phone
Increase font size on Nokia E65 Mobile Phone
NOKIA SAYS THAT THE FONTS ARE NOT CHANGAABLE THEY ARE WRONG!
There is quite a simple way to change system fonts in the Nokia E65 phone.
The following is how I did it in my E65.
First you have to select the memory as phone NOT the memory card.
Then connect the phone to PC through the standard USB cable. When the phone prompts you, select “Data Transfer” NOT PC Suite”. Once the phone is connected you can view it as a removable drive. First check if a directory named “Fonts” exists.
If it does not exist, just create it in the resources folder. If it already exists, just make a backup copy of it.
Now, go to your PC Fonts directory (usually c:\Windows\Fonts) and do the following:
You can use any TT font I used a font called Baveuse.TTF as the bold I used the Baveuse3D.TTF as my normal font. You have to have (3) three fonts and they have to be renamed to what is below or it won’t work.
Copy Any (True Type you want) font file to:\resources\Fonts\NSSB60.ttf
Copy Any Bold (True Type) font file to:\resources\Fonts\NOSNR60.ttf
Copy again the same normal Bold (TT) font file to:\resources\Fonts\NSTSB60.ttf
The (3) Three fonts have to be renamed as above or they wont work!!!
Then just disconnect the phone from USB turn it off. Then restart your phone and put the memory back to the card and you will have the new fonts in place. This is how I did my E65 and it worked ok for me. If the fonts are to big just start over delete the three fonts and use a different font to you find one you like I like the Baveuse.TTF font its personal choice.
Oct 18, 2007 | Cell Phones
Nokia e65 Cellular Phone Logo
238 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
