Question about Daewoo DSP4210GM 42 in. Plasma Television
Daewoo plasma Digital Dream 42in
The screen just says no signal and some times there just greenish purple. Please help.
  • 56 Answers
SOURCE: Vertical bar on Daewoo Plasma screen
The main problem of this model is VPB (video process board) and the reason is they build in it SMD capacitors and they are always crap.First thing that you guys should do is to replace them all but not with SMDs,get a normal capacitors same values.And of course replace all capacitos on PSU.Parts are cheap to buy about 30euros,work on the PSU is easy,only the VPB is tricky but it can be done.It only takes time but belive me don't even think of board replacament its cheeper to by a new set
Posted on Feb 21, 2008
  • 59 Answers
SOURCE: whaere is the scart lead?
Please have a look at the above user manual from the Daewoo site. You may need to down load the Adobe PDF reader if you can't open the file. You can get that from this web site;-
I am not sure that this is exactly your model but one page of the PDF document , page 14 shows the connections at the back of the TV with no obvious SCART connection. So I think you will have to connect the two using a component video cable and the Left and right audio cables as show in the manual on page 28. or via an s video cable and right and left audio cables as show on page 30.
If the connections in this manual look about right for the connections on the back of the your TV set I would be tempted to take this manual printed out (or just the image of the back of the set page 14) down to your local TV shop with the Freeview box and ask them what cables they recommend you use to connect the set.
Also be aware that cables from these TV shops cost a fortune and you can probably buy the cables cheaper on eBay once you know which ones you need. Without seeing the freview box its hard to know what cable options that box offers you.
Posted on Aug 14, 2008
  • 247 Answers
SOURCE: No Signal or Check Signal cable?
did you make sure tv was on the right channel or on the right line (1, 2, or3,) channel? if ao, how old is the ps3? try wiggling the cable in the back of the ps3. it might get the signal to come through. if it that works then the prot on the ps3 is bad. find out if it is still on warantty.
Posted on Jan 03, 2009
  • 113 Answers
SOURCE: purple screen plasma tv
Sounds pretty. Try resetting it to factory defaults, if that doesn't work, it could be the main controler board.
Posted on May 22, 2010
  • 8457 Answers
SOURCE: i have a 42in daewoo plasma tv and it will not
No power at all or the power LED light indication flashes?Yes,the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like, to buy a refurbish power supply board for the replacement.
Posted on Oct 17, 2010
My new 43" samsung 4+
This doesn't sound like an easy fault which you will be able to fix yourself, I would send the unit back for a replacement.
Hope this helps
May 09, 2011 | Televison & Video
I have a 42in daewoo plasma tv and it will not power up at all would it be the power board
Oct 17, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
My P-73 sometimes has a strange purple /greenish color on the display like it is not rendering the colours correctly. Also it shows a strata of lines. Often in bright sunshine. But sometimes OK. Any...
Please open its cover and re-insert its CCD assy flexible cable it is loos thats why purple and greenish color appear. Its part no and description is 1-860-194-11 FP-854 FLEXIBLE BOARDeedc66b.jpg
Jan 24, 2010 | Sony Cyber-Shot DSC-P73 Digital Camera
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Blue screen on everything
Blue screen usually means no signal coming from the source. Did you accidentally hit the 'source' button on the remote, so it is now set to the wrong device (DVD player instead of the cable, for example)?
Jun 09, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a 42in plasma samsung and somehow have sound but not picture, need help. Thanks!
This can be from the power supply, main processor, screen drive, or the screen itself.
The modules must be tried to determine the defective one.
Jerry G.
May 21, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Daewoo Plasma dp-42sm
Just answered this on a different one. I have the Daewoo Plasma Digital Dream model dp-42sm, My dads tv expert friend looked at it and told us the ysus board was out. I got on ebay and bought the item from a store for 125 dollars used tested good with 12 dollar shipping, I put the part in myself it was very simple just take your time dont try and rush you have to take the actual bar the stand hooks onto off and the 2 boards going into the ysus board. It fixed the problem and is still in working order im using it now as the computer monitor.
Feb 28, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
I had the same problem with the flicker. Mine was a Flicker followed by a greenish line through the screen. It got worse then after 2 months the tv stoped working the power didnt come on at all. I Im taking it to bget fixed. The guy said it has somthing to do with a burnt out switch in the unit.
Oct 13, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
No signal report
Ensure that your "video output" on the laptop is on. You usually have to press the Function key (FN) and one of the "F" keys (F1,F2,F3,F4, etc..), The one with a little monitor icon on it. This will toggle the video between the lcd and the TV.
Sep 08, 2007 | LG 42PX3DCV 42 in. Plasma EDTV
Daewoo DSP4210GM 42 in. Plasma Television Logo
450 people viewed this question
Top Daewoo Televison & Video Experts
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
