Question about BenQ (EW162I) DVD±RW Dual Layer Burner
Belt that open disc door keeps breaking unable to find part
I am looking for a dvd-rw that has a gear drive that opens the disc door
  • 105 Answers
Go to any hardware store (home depot, ace, lowes) and get an oring. Same thing. It will cost about a buck.
Posted on Jun 16, 2009
My DvD-rw will not open
This occurs often will CDrom/DVD's. There are two other ways of getting it open. One is to go to my computer, right click on the dvd drive and select eject. The other method is to look for a tiny hole, usually just below the door. Take a paperclip, bend it out and insert this carefully into the hole. This should open the door enough that you can pull out the drive caddy.Sometimes this will be enough to get the drive actiing normally, other times a rubber belt inside the drive has stretched enough times that it no longer opens the door reliably. You usually can continue to use the drive, but eventually you'll find that having to manually eject is too frustrating and replace the drive.
Sep 20, 2012 | eMachines W3107 DVD-RW Combo Drive
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
The recoerder is off and i am stuck on dvd 1 and cant get it to switch back to dvd 3 even if i hold the enter and 3 button down
Hi scooty69,
First you do is to unplug the cord of your DVD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the
DVD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the DVD unit and unplug the unit again to avoid electric shock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn't return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you;
Regards;
VOTIT
Jan 29, 2011 | Sony RDR-VX560 DVD Recorder/VCR
I cannot open the dvd/cd drawer. It sounds like
First you do is to unplug the cord of your DVD/CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug theDVD/CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the DVD/CD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD/CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you; Regards; VOTIT DONT FORGET TO RATE;
Jun 27, 2009 | Bose (321GS) System
Bose 321 dvd tray stuck
First you do is to unplug the cord of your DVD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the DVD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the DVD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you; Regards; VOTIT DONT FORGET TO RATE;
Jun 08, 2009 | Bose (321GS) System
Will Not reconise Cd or DVD in the Drive
Yes, this drive is basically dead. You can find pretty cheap prices for new drives at www.pricewatch.com
If the drive door closes on a cd or dvd that you want and it will not open back up, use a straightened paperclip and push it into the little hole near the door on the drive, the door will pop open then.
Mar 29, 2009 | Sony DW-G120A DVD RW Dual Layer Burner
Dvds locked
First you do is to unplug the cord of your DVD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the DVD see to it if it open If not .Then the other option is to open the cover of the DVD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Regards;
VOTIT
Jan 11, 2009 | JVC TH-M303 System
My daughters locked my dvd player so drawer wont open.
Regards;
VOTIT
Jan 11, 2009 | JVC TH-S3 System
CD-RW Door won't open with disc inside
You need to push harder in the pinhole, and do it while the power is off. That pinhole goes directly to a gear. If the gear is stuck and will not turn at all the drive will have to be disassembled to recover the cd.
Jan 06, 2009 | Sony CRX225E (CRX225E1/10X) CD-RW Burner
Dvd recorder goodmans door sticking
open up your machine then check the cd tray there is a motor that drives the tray. between the motor there are gears which rolls the tray in and out. check properly you will see a belt '' blader kind of'' plz replace with brand new one it will work fresh coz if the belt is worn out then it means motor can not pull the gears to enable opening and clossing of your cd tray
Sep 07, 2007 | Televison & Video
BenQ (EW162I) DVD±RW Dual Layer Burner Logo
217 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
