Question about Acer Aspire 5920-6727 Notebook
Windows boot manager problem acer aspire 5920
I am using acer aspire 5920 laptop. When I turn on my laptop Windows Boot Manager appears and says "Windows failed to start. A recent hardware or software change might be the cause. To fix the problem:
1. Insert your Windows installation disc and restart your computer.
2. Choose your language settings, and then click "Next."
3. Click "Repair your computer."
If you do not have this disc, contact your system administrator or computer manufacturer for assistance.
File : \Windows\system32\drivers\volsnap.sys
Status : 0xc0000098
Info: Windows failed to load because a critical system driver is missing, or corrupt."
I don't have Windows disc. I have tried doing system recovery but it is not working. Is there any way that I colud resolve this problem. Please respond as early as possible. Waiting for the kind reply.
By Manu.
How can i solve my system failure to boot
showing in my acer aspire 5920G booting is missing when i switch it on
Posted on Dec 27, 2012
  • emson4luv247
    emson4luv247 Dec 27, 2012
    how can i solve my system failure to boot
  • 240 Answers
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
Posted on Jun 16, 2009
  • vijay A Jun 16, 2009
    NOTE: Handle these discs carefully and keep them in a safe place. The software allows the creation of only one set of recovery discs.
    Note the following guidelines before creating recovery discs: Use any of the following types of discs: CD-R, DVD+R, DVD+R DL, DVD-R, or DVD-R DL (purchased separately).
    The discs you use will depend on the type of optical drive installed in your computer. Because DVDs store more information than CDs, DVDs and DVDs with double-layer (DL) support reduce the number of discs required.
    NOTE: Read-write discs, such as CD-RW, DVD+RW, and DVD-RW, are not compatible with the Recovery Manager software. The computer must be connected to AC power during this process.
    The computer must be connected to AC power during this process.Recovering system information 103
    Number each disc before inserting it into the computer optical drive
    If necessary, you can exit the program before you have finished creating the recovery discs. The next time you open Recovery Manager, you will be prompted to continue the disc creation process.
    or
    Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how:
    Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.).
    Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
2 Suggested Answers
  • 8 Answers
SOURCE: windows failed coz of critical
That can be frustrating :( hope my solution below helps..
based on the current situation, I suggest trying the following steps: restart the computer and keep pressing F8; Use Last Known Good Configuration.
If the issue still occurs after that, I suggest testing if we can boot from a Windows disk. If so, please install Windows on another partition and access your important data. After backing up those data, you can use Windows disk to format the drive and reinstall Windows.
However, if we cannot boot from a Windows disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
Posted on May 27, 2011
Acer laptop stuck on Windows boot manager
1. Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time.
2. During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup."
3. Keep pressing the "F8" key until the "Advanced Boot Options" menu appears.
If you receive a "keyboard error," restart the Acer Aspire and repeat step 2.
4. Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu.
The arrow keys are located on the right-hand side of the Acer Aspire keyboard.
5. Press the "Enter" key to execute the "Safe Mode" selection.
The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again.
May 25, 2013 | Acer Aspire 5742Z-4601 : 2GHz Pentium...
Acer Aspire 5920 crystal eye webcam is not working. Error: Camera not found.
Hi Friend, In this case i would recommend you to please check if you have the Camera listed under the imaging devices in Device manager.
To get into the device manager
1) If using XP as the Operating system Right click on "My Compuetr" icon, select properties and then select "Hardware" tab from the top and then select "Device manager" Check if you have the camera listed under the device manager
2) If using Vista/ Win 7 Click Start and in search box type "Device manager" and press Enter Check for the camera under the device manager
Dec 11, 2010 | Acer Aspire 5920-6727 Notebook
How to reformat aspire 5920
If you have the factory CD's you can yous that to reformat and install all defaults. If not, you can use a bootable Windows CD. Boot to the cd (pressing F12 as soon as the computer turns on and selecting Boot to CD)
You can the use the Windows CD to format the drive and re-install Windows.
Hope that helps. Please comment and rate if it does.
Thanks,
Oz
Feb 13, 2010 | Acer Aspire 5920-6335 Laptop
Acer aspire 5920 won't read boot config data on start up
hi friend,
operating system of your laptop has crashed. you have to reinstall operating system. entire data which was stored on desktop, My documents will be lost.
Turn on your laptop and open DVD rom. Insert bootable CD which you might got with laptop. then it will start itself. and follow the instructions given on the screen.
Your friend,
Anil
Sep 21, 2009 | Acer Aspire 5920-6335 Laptop
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
My Acer cannot log in the normal screen but the safe mode
Do you see the white cursor on the black background? If so, press CONTROL+ALT+DELETE keys. If the Task Manager window appears. You can start the PC from the CD/DVD and choose Startup Repair from the choices given.
Apr 19, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 problem
Your best play is to restore the machine to the factory settings. To do this, power up the machine and immediately press ALT+F10. From there you will enter Acer eRecovery Management which will give you the option of returning the machine to the factory settings.
WARNING:
This will erase everything you had stored on the machine!! ie data files, pictures etc...
Apr 12, 2009 | Computers & Internet
Just reformatted an aspire 5920 with the boot sector of the hard drive, but the audio doesn't play. Device drivers fine and did all upadates?
Go to control panel to makesure nothing is on "mute" then, check on the device manager to see if your divice is showing there...
get back with me on that.
Apr 10, 2009 | Acer Aspire 5920-6727 Notebook
I can not get my Acer Aspire 5920 to load after turning on.
Try to see if it will boot in safe mode, by pressing F8 while the laptop boots up. If it allows you to boot in safe mode, try to do a system restore when you know that laptop was working with no problems. You can do this by clicking on start>all programs>accessories>system tools>system restore and choose a date and time when you know that the laptop was working with no problems. If this does not work or you cannot boot in safe mode (be aware that everything will look big in safe mode and when the computer reboots if asked how you want to start windows, choose start windows normally), try doing a recovery. This will restore your computer to the factory default settings when you purchased it. You can do this by booting the computer, when the acer screen appears hold down the ALT key and continuously press F10, this will open the recovery manager and you can restore it from there.
I hope this helps
Jan 20, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920-6727 Notebook Logo
2,955 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
