Question about Brother MFC 7420 All-In-One Laser Printer
It is installed on one pc (prints from there) and is shared with the other pcs in the office. I haven't tried printing from other pcs yet, when I try to do a test print from my pc it wants me to set up my cover page for the fax.
    Sniper:
  • 86 Answers
Sounds like you have checked the PC-Fax as the default printer instead of the actual printer. Check by going into Start -> Control Panel -> Printer & Faxes. If the MFC-printer isn't set as default printer, right click it and choose "set as default". You could also try printing a test page by right clicking, choose Properties and then you'll have the test print option on a button in the bottom left part of the properties screen.
Posted on Jun 16, 2009
Make my Lexmark x5340 be wireless'
Is this a wireless printer? Is it being used for a large office or a small home type office? If you are using it for a home office and have multiple pcs, then you can setup a homegroup. A homegroup is like building your own personal small network. You will be able to share and print documents between your computers. Once you setup the homegroup, on one computer, then you will have to add the other computers to the group using the access code that the first computer will provide. Be sure to enable printer and file sharing when setting-up the homegroup. Once setup, you will be able to print your documents from any connected printer on your network. It's not wireless but it might help to solve a print sharing problem. Good luck. How To Set Up Homegroup Sharing Plus Printer Sharing
I’m happy to help further over the phone at https://www.6ya.com/expert/darnell_06979bec4e109662
Dec 22, 2014 | Lexmark X5340 AllInOne InkJet Printer
I'm connecting 2 PCs to 1 printer .... using "Manual Share Switch #MT-1A2B-C" device. It seems an extremely uncomplicated connection to me. However, neither of the computers recognize a...
Hello.
Try connecting one of the PCs to the switch to see if it prints. If still no printing, then the share switch is probably faulty.
Hope this helps.
Jan 13, 2011 | Computers & Internet
HOW DO I USE A WIRELESS PRINTER WITH NO ROUTER. I WANT TO PRINT FROM TWO COMPUTERS, THAT BOTH USE DIAL UP INTERNET
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
Wireless printing does not work
For an effective wireless connection, the printer should be connected to one of the LAN ports of a configured wireless router. This way, every pc(mostly laptops with wireless capability) can print to the printer. You will need a wireless adapter for desktop pcs to access any resource made available wirelessly ok. Good luck
Jun 02, 2009 | Canon PIXMA MX850 Multifunction Printer
Sharing HP PSC 1410V All-In-One
Yes, you can and it is pretty easy.
You should get the HP Wireless Printing Upgrade Kit
(Q6236A#A2L)
Price: $69.99
Here is there product description from HP.
Get everything you need to print wirelessly in this simple upgrade kit! It includes a printer receiver and PC receiver for a wired desktop or notebook PC, and it's easy to both install and use.
Works with most HP printers and All-in-Ones, plus all PCs, wired or wireless.
* Print from virtually anywhere in your home or office via the wireless 802.11g connectivity
* Eliminate ugly cable clutter but still get the same print speeds as via USB
* Retain full all-in-one wireless functionality: print, fax from your PC, scan, and access photo memory cards access and PC status
* Set up fast: just plug the receivers into your printer and PC; there's no configuration
* Protect your signal from interception with the secure wireless connection
* Use with a network, or just one PC
* Compatibility: most HP printers, all PCs (wired or wireless)
** I checked and your HP is on the compatibility list - it is ok***
What's in the box?
1 printer receiver
1 PC receiver
William
Feb 15, 2008 | HP PSC 1410v All-in-One Printer
Wireless printing
The MP830 does not include the ability to do Wireless Network printing. You can however, connect this printer to one of your Windows or Mac PCs and share it on the network, which is wireless, therefore accomplishing the same thing.
1) Install the Drivers and Software that came with your Printer.
2) Go to the Control Panel > Printers & Faxes
3) Right-click your printer and click "Sharing"
4) Choose Share this Printer, and give it a name.
5) You can then on, use the Add Printer Wizard on any other Windows PC and install it by searching for network printers.
Step 1 is the same for Mac
2) Go to System Preferences > Sharing
3) Check the box for Printer Sharing
4) Any Mac on the network can see it!!
5) Added treat: go to http://apple.com/bonjour to install bonjour for Windows, using this software you can print using any Mac printer on any PC
Jan 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Sharing with Samba/Cups
To my best knowledge, you cannot. The drivers and scanning software on your unit are not designed to support network protocols. Your unit does not come with an Ethernet adapter and it is not available as an option. When Samsung fits an equipment with a network card (such as the SCX-4521FN) the drivers and software are enabled for network use. By the way, your toner will only last for 3,000 pages. Are you sure it's a good idea to share such such a small unit over a 10 PC network?
Sep 25, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Printer will not network
Hi Stukie, Something you can try. Install the downloaded "newest" driver in all you PCs and laptops even if they cannot see or share with the PC print server. If you can successfully install on each PC, then you try changing the port setting of the printer on each PC. Go to Start, Printers and Faxes, Right click on the HP LaserJet 1000 (assuming you were able to install on every PC), click on Properties, click on Ports Tab, Click on Add Port, Double click Standard TCP/IP Port. A new window will pop up > Add Standard TCP/IP Printer Port Wizard, in the IP Address, type in the IP add of the PC where the printer is installed, Port Name can be any name but try the Shared Name of the Printer, Next and follow all other instructions. Hope this works for you and pls post again how things turn up. Kind regards.
May 22, 2007 | HP LaserJet 1000 Printer
Brother MFC 7420 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
