Question about NEC Versa LX Notebook
Pc battery problem
When i unplug charger port, automatically power is gone. I want solve this problem.
  • 157 Answers
You need to buy a new battery.
Posted on Jun 16, 2009
Hcl me laptop 39 s.no.1104ax259318
Battery issue? Try a fresh battery.
Feb 06, 2014 | Computers & Internet
My dell studio 1737 has gone dead.
For a new battery, we advise that you update the BIOS of your laptop, and open the hardware automatic identification port of your laptop.
When you use it firstly, you need to discharge till 5%, then charge it about 11 hours. Usually, new battery need to fully discharge and charge for three or four times, which can achieve the best performance.
About the new battery, please set the power management of your laptop: Property -> Screen Saver -> power -> Power scheme -> Portable / Laptop -> please cancel about low battery alarm and serious shortage of battery alarm when use the battery.
For some laptops, you could try to close your power management tool to test your new battery.
You could try to take out the battery from your laptop, and put it back again, repeat several times. Make sure that it isn't a poor contact problem between the battery and your laptop.
If the battery works in higher temperature, the battery protection plate will work and the laptop restart program will make a termination order. You can take out the battery, put it back again, and avoid work in high temperature.
In order to avoid some damage to the battery, please note:
Please don't take out the battery when the laptop is in run status.
Please don't pull out the ac adapter frequently when the battery is charging.
Please use high quality and reliable laptop charger, not to use the universal laptop charger.
Are there something wrong with the new battery can not charging?
That's not usually the case. When equipment for the first time to recharge the battery, the instability of the voltage and current may cause the battery charge to 50% (sometimes more, sometimes less), and equipment stop charging the battery.
If this happens,don't worry. You just remove the battey from the equipment, recharge again. First charging a new battery may need several repeated process. Please be assured that this is normal.
Many people have reflected that Dell's notebook haven't recognised and charged the new battery problem. Usually, they solve this problem via BIOS refreshed.
Usually, please connect the battert with the power supply when you can refresh the BIOS. You can download the BIOS program from Dell support website http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=dell+bios+inspiron+6400&cat=sup, automatically installed and automatically restart till to complete. Of course, you could check its use manual in advance.
Or you can visit http://www.batteriescenter.com.au/.
Mar 25, 2012 | Dell Studio 1737 Laptop
My laptop wont charge when charger is plugged in it will turn on but the computer will stay at 0% battery what is the problem?
HI there, IS it a new Laptop. If yes what you can try is removing the battery and then switching it on.. Once its started just reseat the battery while its on power. You might have to try it 2-3 times if that doesnt help then your battery is broken..
Kind regards
Jul 23, 2011 | Toshiba Satellite L305-S5908 Notebook
Hp pavilion dv-7-1245dx --keep shutting down after a few seconds
If the computer's battery is bad it won't stay on. If the fan is plugged up and over heats quickly, then the computer will shut itself down. I would start with those. Wouldn't be bad to check that your memory chips are in securely as well.
Jan 06, 2011 | HP Pavilion dv6000z Notebook
My Asus eee pc 901a: i get no charge lights i get no power light even when the charger is pluged in. ive gone as far as unpluging bios battery and replaceing. any suggestions
Hi. This could be a power adapter problem. Try this troubleshooting first, if nothing happens then i suggest you purchase a new adapter. Take out the battery and unplugged the power adapter to the wall socket. Press and hold the power button for 30 secs. Put everything back in then turn ON the computer.
Sep 02, 2010 | Computers & Internet
Press power button, button luminates plus WiFi sign then goes out computer does not boot. what is wrong?
check if the battery is getting charged or not-->the charger might have gone bad & u might have exhausted the charge in the battery-->thats y it gets turned off-->c if the light around the port in the notebook where the charger gets connected is glowing or not-->if its glowing then the charger is working absolutely fine otherwise the charger might have gone bad-->u can also c if the brick in between the 2 wires of the charger is getting warm or not in order to check whether the charger is working fine-->if the charger has gone bad then u will have to buy a new charger...
Jul 08, 2010 | HP Computers & Internet
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
The laptop is not coming on
hello
I suggest you a few steps to solve your problem.
  • remove the charger and press the power button till all residue power is radiated.
  • then connect the charger and charge the battery fully and try booting the system.
  • if this don't work check the output of your charger and see if it is working fine.
  • if it is working fine then remove the battery and connect the charger and try starting the system.
  • if it works then there are two things possible.
  1. battery gone.
  2. IC responsible for charging is gone.
if this don't work out then your RAM is gone.
i hope you can figure out the problem through this.
Thank you.
Aug 16, 2009 | Fujitsu Siemens AMILO Xi 1546 Notebook
I have an acer 5920 laptop will not turn on. when i plug the charger into the wall socket the charger has a constant green light. when i plug the charger into the computer the green light flashes the...
sounds like the power jack at back of computer has gone bad, check voltage of battery and see if it has good power if not then it is dead and not getting charged through port the jack at rear generally requires MB replacement and is very expensive and cheaper to get new laptop, u can remove HD from old lap top and copy data over. another choice is to get stand alone charger for laptop battery and use battery mode,
if battery tested good them there is slight chance power switch is bad
Jul 07, 2009 | Computers & Internet
NEC Versa LX Notebook Logo
37 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
