Question about Samsung TX-T3093WH TV
Hi, my samsung LE32R73DB died during a xbox game.
Hi, my samsung LE32R73DB died during an xbox game. the picture disappeared and i was left with a bunch of vertical different colored lines no channal number .. nothing. the sound was fine and still is. i put the tv aside for about a week and then decided it was time to get to the bottom of this, so i turned the tv back on and ... it worked. so i decided to play a game. 5 minutes in ... same thing happened. what part do i need to replace. Please help me.
thank you
    Top Expert:
  • Samsung Master
  • 75,581 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Posted on Jun 10, 2017
jerryg50
  • 1689 Answers
SOURCE: 46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Posted on May 06, 2008
lukster
  • 217 Answers
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Posted on Aug 03, 2008
  • 98 Answers
SOURCE: Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
version.
If you match that version, can play.
Posted on Mar 05, 2009
tvservice306
  • 458 Answers
SOURCE: There is a picture but it is all different colors
replaced main board
Manufacturer Samsung Part Number BP94-02065A Description ASSY PCB MISC-DIGITA
Posted on Nov 01, 2009
  • 17 Answers
SOURCE: HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Posted on Jul 23, 2010
My xbox remote won't pause during playback
I hate to say this but it may be time for a new xbox remote.
Jun 07, 2013 | Microsoft Xbox 360 Wireless Controller
Playing call of duty mw3
It's possible that you are suffering from lag issues when playing games online. Check your internet connections to see if everything is working properly.
During a mw3 match, do you usually watch the kill cams? They usually tell you how you died and to see if your opponent was obviously cheating or not.
Feb 23, 2012 | Activision Call Of Duty Modern Warfare 3...
My microsoft xbox console stalls during use
The Original X-box console are OLD. upwards of 10 years and better. This is a common problem with ANY older system (gamecube, Xbox, Playstation 1 and 2).
This also means that your problem could be any number of things from the motors or hard drive dying to the laser kicking itself in and out of alignment. Best bet is to upgrade your system :(
Jul 24, 2010 | Microsoft Xbox Console
A series of dots appear on the monitor but no game pictures
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the Video card inside the xbox 360 is having an issue
Apr 07, 2009 | Microsoft Xbox 360 Console
Xbox- No signal to TV
Before the xbox stop working, the graphics where blurry, or small ojects disappear from the screen. I ask this because it could be GPU that is bad. I remember an xbox that I fix that have a similar problem, when you put Final Round, the fighters on screen disappear or their legs or hands disappear. That occur because the GPU didnt have thermal paste on the heat sink and it was causing overheating.
Aug 26, 2008 | Microsoft Xbox 360 Console
Connect
Clear your cache and then try it again...!
Go to the Xbox Dashboard, select the System Blade, and select Memory.
Highlight the HD symbol and press Y.
Press X, X, Left Bumper, Right Bumper, X, X.
Note: Game saves, user profiles, demos, videos, music will not deleted during the process - But all game/console updates and error logs will be deleted.
Cheers
Jun 06, 2008 | Video Game Consoles & Games
Game reading Problem
Have you tried clearing the cache?
  • Go to the Xbox Dashboard, select the System Blade, and select Memory.
  • Highlight the HD symbol and press Y.
  • Press X, X, Left Bumper, Right Bumper, X, X.
  • Note: Game saves, user profiles, demos, videos, music will not deleted during the process - But all game/console updates and error logs will be deleted.
    Cheers
    Jun 04, 2008 | Microsoft Xbox 360 Console
    Slightly over one side
    hi mate you just need to lower the resolution in the display settings
    Jun 03, 2007 | Microsoft Xbox 360 Console
    Samsung TX-T3093WH TV Logo
    67 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
