Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Caller id button is not working - Uniden DECT 6.0 Cordless Telephone Expansion Handset
    New Friend:
  • 70 Answers
Try to change the battries of your phone.
Posted on Jun 18, 2009
How do i turn the voice off n my panasonic 6.0 phone
How do I turn off the Talking Caller ID on my phone? To turn off Talking Caller ID on the base;
  1. Press [MENU] [#] [*] [1] [6] [2]
  2. Press the [?] or the [?] button to turn the base Caller ID on or off.
  3. Press [ SAVE ]
To turn off Talking Caller ID on one of the handsets;
  1. Press [MENU] [#] [1] [6] [2].
  2. Press the [?] or the [?] button to turn the handset Caller ID on or off.
  3. Press [ SAVE ]
Note that the base and each handset are programmed individually.
Jan 16, 2018 | Panasonic Lands Phones
How do i. Turn the voice off on my panasonic 6.0 phone
  3. Press [ SAVE ]
  3. Press [ SAVE ]
How can i turn the voice off on my panasonic 6.0 plus phone
Press [ SAVE ]
Press [ SAVE ]
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
How do i get caller id on main phone line
Do you have caller ID service from your phone co.?
Jan 22, 2015 | Panasonic KX-T7731 Corded Phone
I have caller ID service for our business account and our phone has a Caller ID button, but it doesn't seem to work?
I you're running on a CiX or CTX platform, you're dealer or system administrator needs to enter the amount of CID calls to be buffered on that particular phone. This can only be done via the System Administration Program.
Sep 17, 2014 | Toshiba DKT3020SD Corded Phone
I HAVE A PANASONIC KX-TGA402 CALLER ID NOT WORKING
I purchased one cordless telephone (Siemens Gigaset) in Germany. I also had the same problem, caller-id did not work. I purchased this telephone because we can set different ringtones for different caller groups. But, if caller-id doesn't work, this feature also doesn't work. I had gone through internet and finally found that CA electronics, Bangalore has it and got it through courier (I live in Pondicherry). It worked flawlessly for two years. Then it stopped working. For 'no reason' I ordered for a 'caller-id' unit on ebay for Rs.75/- (+ Rs.75 shipping). I just got the unit and fixed it to my line. Very very surprisingly, my cordless telephone is now showing caller info. This is a real surprise to me. By the way, caller-id unit is "Eurotel" make, DTMF/FSK caller-id. I feel this is very nice solution. The 'caller-id' unit is nice (backlit display) and also there is no need of converter for using the caller-id feature of your foreign telephone. I connected caller-id between the line and telephone. That's all. Enjoy.
Jun 14, 2012 | Panasonic Lands Phones
Caller i.d. doesn't work piece of junk
Please download this manual, and study e.g on page 21 About caller ID If you subscribe to caller ID service from your local telephone company, this feature displays the name and telephone number of the caller before answering a call (even when you are on another call). The caller ID features of this product will work only if you subscribe to caller ID service and both you and the caller are in areas offering caller ID service, and if both telephone companies use compatible equipment. Contact your local telephone company if: • you have both caller ID and call waiting, but as separate services (you may need combined service), • you have only caller ID service, or only call waiting service, • you do not subscribe to caller ID or call waiting services but wish to try them. There may be fees for these services, and they may not be available in all areas. This product can be used without subscribing to either caller ID or combined caller ID with call waiting service, although the caller ID features of this product will not function.
http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i4.pdf
Mar 12, 2010 | Vtech Cordless 6041 Phone
Caller id not working
the directory key is storage for caller id. dtr80 is not the type of system but the type of phone.
The system needs to have other components like a mif card in order to store caller id.
Also if your phone does not ring with incoming outside call than you will not get caller id.
Oct 03, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Caller id dont work
just connect one end of the phone plug to the id caller,then connect the outlet of the caller id and fix it to phone...........even then if u hav problem, may be ur caller id doesn.t hav batteries..............otherwise u may hav some problem in the id caller socket where phone plugs r inserted................
Sep 08, 2008 | Radio Shack 433575 Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
175 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
