Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I have a problem with a bizhub c451
If i try to print the copier will display the paper tray and print Ther is no matching paper please use the side tray and all trays are full of paper
    Problem Solver:
  • 7 Answers
Sometimes especially when printing a pdf there is a box on the first print screen that pos up that says print actual size deselect that and then it will default and print on the paper that is available
Posted on Aug 22, 2009
  • 32 Answers
You need to select the tray you want to print from on the print driver and on the document you are sending
si
Posted on Jul 03, 2009
Code c202 bz c451
This sounds like you have a piece of paper behind tray one.
1. Turn the machine off
2. Take out tray 1
3. Remove paper
4. Insert tray
5. Turn back on
If that doesn't help, you have and issue with the paper pick up motor. This is 99% of the time not the issue. The paper behind the tray is most likely your problem.
Oct 08, 2014 | Konica Minolta 4053-401 Black Laser Toner...
Printer is only printing to the bypass tray instead of tray 1 where it should be printing
First, check your printer properties and make sure you are not telling it to go to the bypass tray.
If you are set to auto tray and its still trying to pull out off bypass tray. Check on the copier to make sure tray 1 isn't set for a special type of paper. If it is, change it to plain paper.
Sep 30, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Konica Minolta C451 is ghosting only black color and ONLY when duplexing (first side is OK, just second side is ghosted). Black parts of print looks like smeared in direction how paper moves through p
what media are you using and what is the weight of the media you are using and does the copier know this and is correctly set
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 23, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Paper Jam Konica Minolta BHC451
Is the thick 4 11 x 81/2? take the paper off the bypass tray, first send the job to the copier selecting the bypass tray the copier is going to beep telling you replenish paper in the bypass when you place the paper in the bypass make you follow the orientation of the paper on the copier screen.Might also want o replace the bypass tray roller set. If the Plain paper through Thick 3 work then you did not need to replace the main board. Are trying to duplex the paper????? When it jams where does the paper stop??
Dec 16, 2017 | Konica Minolta Bizhub C451 Copier Print...
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
My Konica Minolta bizhub C250 seems prints about every 10th page crinkled and crooked. I can hear it going through the machine and crushing a crease in the paper as it prints. The printed also seems to...
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Dec 07, 2010 | Konica Minolta bizhub C250 All-In-One...
I cannot figure out how to print envelopes on my bizhub 200. When I select bypass tray from Word and envelope for type it still prints from the regular tray? Please help. I don't have an option to select...
Chances are your print drivers haven't fully recognized the configuration on your copier/printer.
Click on 'Start', then 'Printers and Faxes' (I'm assuming you're using XP), then find the icon for the bizhub printer. Highlight it, then right-click over it and choose 'properties' at the bottom of the list.
In the window that pops up go to 'printer preferences' and it should launch another pop-up window. Look within the tabs that appear for a button that says 'auto detect' or 'auto configuration' and click on that. Then hit 'apply' at the bottom of the window.
This will allow the print drivers to fully recognize the configuration of your copier/printer, and you should then be able to use the bypass tray. Make sure the paper in the tray matches the paper you're choosing in the print job.
Aug 28, 2009 | Minolta bizhub 200 All-In-One Printer
Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Mar 30, 2009 | Konica Minolta bizhub C450P Laser Printer
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
538 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
