Question about Dell 3100cn Laser Printer
How to close the large back panel door? The door will not close and latch into place.
Disconnect the power and ethernet cable, open the lower paper tray slightly, turn your printer around where you have easy access to the back of the printer. Close the main door until it has full resistance. ( The lower right hand corner of the door will be bowed out. ) With the heel the the palm of your hand, "pop" the lower right hand corner of the door, swiftly. Turn printer around, push tray in, reconnect cables, and turn on printer with power switch.
Posted on Sep 28, 2009
Finaly got it closed wiggling the door.
Posted on Jun 17, 2009
I have a 1996 chevy suburban and my passenger door isn't closing nor latching on how can I fix this?
Look at the latch, if it sprung closed when the door was open then the latch hits the bolt when it closes. If the latch is closed you can take a rod like object and press the latch back into place while someone pulls the door handle.
Jan 01, 2015 | Cars & Trucks
The back glass after opening it, it wont close unless i stick my hand inside the door panel and push the lever that allows the glass to shut. i am trying to find the part for it and i am not having any...
Its called the rear glass latch or rear window latch. It would be available thru a dodge dealership, but obviously expensive. You may try a large parts store like Autozone or Pep Boyz. The third alternative is to call auto wreckers in your area. Its the same latch from 2000-2005 Liberty's. It isn't that hard to remove. The rear door panel needs to be removed, then the latch is attached with 2 bolts, and an electric cable.
Apr 08, 2011 | 2003 Jeep Liberty
My front door will not close because latch has locked in place, help 1999 Chevy astro van
You should be able to open it with a large screw driver. Simply put the screw driver in the hole where the latch would go and pull the handle to open the door. With the handle in the open position pull the screw driver toward the inside of the van and the latch should open right up. Then close the door. Hope this helps.
Jul 26, 2010 | 1999 Chevrolet Astro
How do I remove the driver side door panel to get to the door latch. The door latch will not release from the outside or inside. I need to be able to remove the door panel but cannot open the door.
if you can't open the door fromt inside or outside, you might have to cut the metal piece that the latch connects to when closing the door, using a sawzall.
I learned this trick from a local body shop where I live.
Replacing the piece is easy, with a large Philips bit.
Cheaper than ruining a door.
Jun 26, 2010 | 1998 Honda Accord
Dryer door won't stay shut latch won't catch
If this specific dryer has the door that opens forward (top to bottom as opposed to left to right, etc...) the common problem is that downward pressure on the door has bent it slightly. This happened on mine when one of my daughters would lean on the door while loading and/or unloading the dryer. If this is the case, then the door may pop open while running even though the latch looks good.
The best way to tell is just let the door rest naturally in the closed position. If it does not rest all the way closed, then the lower portion of the door & frame has been slightly bent as indicated above.
The door & frame has to be slightly bent/forced back out at the bottom. This can be accomplished with a large screwdriver or something similar such as a paint mixing paddle or basically anything that will fit between the bottom of the door (from the inside) and the dryer frame. Very slowly close the door with the paint paddle or large screw driver in place (again on the inside...not from the outside of the door). The goal is to just barely force the bottom of the door framing back out without warping it grossly.
Just take your time and be as gentle as possible & make small adjustments until the door will remain closed and latched.
The latch is really only required to keep the door secure while clothes are beating against the door interior. Proper alignment actually keeps the door closed.
Let me know if this helps.
May 06, 2010 | Whirlpool LEN2000PW Dryer
Can't get door open
wiring connections or lock latch frozen --to manually bypass latch or to unlock rear hatch -- in the bottom of door panel is a round access hole remove cover just clipped into place using a flashlight and a screw driver about 3 inches in on bottom is the lock latch and window lock latch connections if u pull back on the inner latch u will unlock the hatch which will allow u to open it[ when opened check the wiring connections for corrosion or damage if good ] now u can remove the whole hatch panel and check the latches and actuator the actuator and latches,and rod clips sometimes need to be lubed or sometimes the clips break or disconnect clips can be purchased at any auto store panel is clipped into place carefully pry from a corner and using a screw driver or panel tool pry straight back till panel clip pops replacement of panel put clips in place and push in panel
Feb 08, 2010 | 2005 GMC Envoy
Front door latch on astro won't allow door to close
use a large screwdriver,tire iron or a wooden spoon[?] inserted into the 'hole'between the latch levers,where the post should be.lift door latch as if to open door,pull/pry latch 'ears' open.if they don't stay in place when opened fully,latch may be broken.
Oct 10, 2009 | 1988 Chevrolet Astro Cargo
How to replace door handle cable on 1993 ford f150
watch for sharp edges and pay close attention to where things connect.there is no easy way i have found to do this.
Apr 01, 2009 | 1993 Ford F150 SuperCab
Door latch
The latch is fairly simple to replace. There are several screws around the inside of the door that hold the inside panel in place. You then will be able to slide the panel out of the way (it is attached by wires).
You will then be able to access the latch it is not attached by any screws, but there is a wire harness on each side of the latch. There are two clips that you need to hold out of the way and slide the black harnesses off the two pins on the latch.
Then simply replace the latch and close up the door and your problem is fixed.
Dec 26, 2007 | Maytag 24 in. MDB6600A Jetclean II...
Dell 3100cn Laser Printer Logo
421 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
